Go Back   Home > Forums > Amplifiers > Power Supplies
Old 8th September 2010, 12:14 AM   #11
TechGuy is offline TechGuy  United States
Originally Posted by kall View Post
is this really a good approx?, i found this very simple...
i have a case with 100kHz 20V 210A (i guess MOSFETs are the only option here?)
any rule of thumb what "size" to choose to have a good "safety margin", go up to 40V, 60V??
Which such a low input voltage and high frequency MOSFETs are the practical way to go. Safety margin will depend on the topology. for instance for Push-Pull the switching transistors need to have at least twice the device voltage rating. It also depends on how much inductance leakage your transformer (or inductor) will create and how aggressive your snubbers are. It might make sense to use higher voltage rated MOSFETs during your initial testing until you are able to measure inductance leakage spikes in a working circuit.
I think your first big problem will be laying our your circuit that is capable of sustaining 210 Amps and not having layout problems picking up excessive switching noise. 210A is going to require a lot of copper. FWIW: I would recommend doubling or tripling the input voltage to reduce the input current demand. If you haven't noticed, Copper is pretty expensive these days. Its going to cost you a small fortune in copper to pass 210 amps!
Old 8th September 2010, 08:17 AM   #12
kall is offline kall  Sweden
thx for answering...
im using a fullbridge topology with input 400V, i have 20V on the low-voltage side... i was thinking of using sync. rect.(MOSFETs) instead of diodes for rectifying to reduce my losses..
Old 13th September 2010, 05:01 PM   #13
darkfenriz's Avatar
The approximation is rather bad, especially for synchronous rectification.
Note that with synch rect. the switching is nearly soft, i.e. mosfets work at near zero voltage.
help !! calculating switch losses dead rat Class D 0 16th December 2008 03:33 PM
Estimating leakage, absorption and port losses bmansz Multi-Way 7 1st November 2008 01:18 AM
Reverb insertion losses ThSpeakerDude88 Tubes / Valves 5 28th January 2008 02:50 PM
Why i always have those losses in power using lower impedance loads? destroyer X Solid State 12 5th June 2007 03:49 PM
Mesure box losses REALFLEO Multi-Way 2 7th February 2007 01:06 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
