How much does a 300 VA trafo weigh
Old 31st August 2010, 02:45 PM   #1
goldyrathore is offline goldyrathore  India
Default How much does a 300 VA trafo weigh
I would like to understand the weight difference of EI trafo against a toroid trafo.
How much would a 300VA trafo typically weigh in both the forms?
Thanks,
Goldy
Audio enthusiast/hobbyist
Old 31st August 2010, 03:25 PM   #2
donpetru is offline donpetru  Romania
donpetru's Avatar
Weight transformer don't tell us nothing about the power transformer (just give us some clues, but elusive). Leakage magnetic field of a toroidal transformer is much smaller than that generated by a transformer core E + I. Toroidal transformers are made in three standard heights: high, standard and low profile.
For example (weights according to standard SR EN 61558):
1.Toroidal transformers 300VA:
- high profile - 2.97Kg (6.54 lb. lbs);
- low profile - 2.85Kg (6.28 lb. lbs);
- standard profile - 2.92Kg (6.43 lb. lbs);
2. Electrical transformers with core E + I - 300VA = 4Kg (8.81 lb. lbs).
AV400v2 and GX400 audio amplifier projects
PCB Design Services - for prototypes OR serial products, Today Tehnium and Forums
Old 31st August 2010, 06:43 PM   #3
TechGuy is offline TechGuy  United States
Thanks,
Goldy
Switching frequency is an important factor in the amount of power a transformer can handle. A very high frequency AC input needs a small core to pass a lot of power. At lower switching frequencies a bigger, heavier core is required. This is why a 500 Watt linear power supply operating at 60\50 hz is heavy but a 500 Watt Switch mode power supply is fairly light weight.
That said, different core materials are required to operate at different frequencies. At low frequencies steel plates (usually silicon steel) can be used. However, at high frequencies eddy currents rise causing excessive power loss, turning the transformer into an induction heater. Typically, at higher frequencies, ferrite is the core material used because eddy currents remain low.
Old 31st August 2010, 08:14 PM   #4
donpetru's Avatar
Returning with a supplement: weights transformers exhibited by me above are for 50 Hz single phase electrical transformers.
@goldyrathore, I think this type of transformer you meant!
Old 31st August 2010, 08:30 PM   #5
PMA is offline PMA  Europe
PMA's Avatar
My 300VA toroidal transformers in this:
have 3.0 kg each.
How much does a 300 VA trafo weighHide this!Advertise here!
Transformer VA versus output power VA nigelwright7557 Solid State 8 18th May 2008 02:57 PM
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 12:30 AM
humming 2x25volt 300 va trafo marn_x Swap Meet 6 17th May 2005 09:40 PM
2 Velleman 1000 VA 45V trafo Duck-Twacy Swap Meet 0 10th September 2004 06:10 PM
300 VA toroids on offer! Andypairo Swap Meet 1 23rd October 2003 07:16 AM
Copyright ©1999-2017 diyAudio
