Go Back   Home > Forums > Amplifiers > Power Supplies
Old 27th August 2010, 12:24 PM   #1
sajti is offline sajti  Hungary
Default ARC style regulated psu, tubed
I like the ARC style, well regulated power supply. The only thing I hate, is the MOSFET, they use as series pass element.
I try use tube in that position. The circuit is not yet tested, because of my limited time.
Please comment the circuit! Is it worth, to try?
Sajti
Old 27th August 2010, 12:29 PM   #2
SY's Avatar
Why not use Jan Didden's well-designed and proven T-Reg?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 27th August 2010, 12:36 PM   #3
I don't know T-Reg. I just want to plan something by myself.
Sajti
Old 27th August 2010, 12:43 PM   #4
SY's Avatar
Nonetheless, you want to at least read through Jan's article about it (I think it's on his linearaudio.nl website) to see what sort of engineering decisions have to be made and what the tradeoffs are.
Old 27th August 2010, 12:57 PM   #5
I just checked his website. T-Reg looks quite good. I hope, that my regulator can gives same good results.
Sajti
Old 27th August 2010, 01:22 PM   #6
There can be some planning decisions, I have to explain:
I use 6550, because I have some of them. And the parameters are ideal for this application. The power supply should give 330V/40mA. This means 120V on the 6550, and -Ug1 about -7-8V, which is acceptable for the opamp.
For lower output current ECC99/5687/ECC82 is useful as well.
I use no series pass triode, such as 6AS7G, because they need more negative grid voltage, which is out of the opamp's output range.
I use the 6550 as tetrode, not as triode. Triode connection can be more simple, without 100uF capacitor. But the additional filtering on the 2nd grid means much better ripple rejection without increasing the loop feedback.
Sajti
plain Big caps on psu vs. carlosfm style Snubber shiraz Chip Amps 25 9th September 2008 03:11 PM
Choke loaded PSU versus VR tube regulated PSU? G Tubes / Valves 37 20th March 2008 10:45 PM
Regulated or no regulated PSU? Higo Chip Amps 2 16th July 2003 04:38 PM
Page generated in 0.09179 seconds (75.57% PHP - 24.43% MySQL) with 11 queries
