This is a simple question, but at this hour I can't figure out what I'm doing wrong.
I'm using LTspice to simulate a simple rectifier circuit using a sine wave generator (24 V, 50 Hz), a full wave diode bridge, a reservoir capacitor (2200 µF) and a load resistor (1k). I was expecting to see approximately 24 * sqrt(2) - 2 * 0.65 (diode drop) = 32.5 V, across the load resistor (plus some ripple). Instead, I'm seeing 23.3 V. What am I doing/thinking wrong? Screenshot attached. Regards, Alexander |
#2 |
24 V is the amplitude of the sine source - ie the peak values are +/-24 V
you have to multiply your argument in the sine source parameter list by sqrt(2) if you want "rms" |
#4 | |
jd
/Another new issue: Linear Audio Volume 3! |
#5 |
Well, of course. Thank you!
![]() Ever since I started playing/working with electronics (which isn't many years, but still), I've had the intuitive view of the RMS voltage of an AC signal, as a rectangle which occupies the same area under the graph as a sine wave does over the same range. Mathematically speaking; integrate abs(sin(x)) (a rectified sine wave) over the range of 0 to a (a = 2*pi*k), and divide the sum by a to get the height/amplitude of the rectangle that you've created. Example: Integrate abs(sin(x)) over 0 to 2*pi = 4. Divide 4 by 2*pi = 2/pi ≈ 0.637. 0.637 V would then be the RMS voltage of an AC signal with a peak voltage of 1 V. I did some calculations and found this terribly wrong. The real RMS voltage of an AC signal with a Vpk of 1 V is 1/sqrt(2) ≈ 0.707 V. What am I missing? |
#6 |
Why is LTspice reporting one diode Vdrop?
24Vpk and 23.3Vdc equates to a 700mV Vdrop?
regards Andrew T. |
#7 |
Probably because those are Schottky diodes, and because the current is quite low. Forward voltage drop is a function of the forward current.
Do wizards use spell checkers? |
#8 |
so that means the simulator is reporting 350mVdrop for each diode passing 23.3mA.
Correct?
regards Andrew T. |
#9 |
I'm sure Spice aficionados can chime in here, but I'd prefer to say that "the model used for the diodes result in a 350mV drop at 23.3mA". LTSpice isn't really reporting the voltage drop across the diodes. It uses whatever the model tells it to.
#10 |
yes, we agree.
regards Andrew T. |
| Simple SE and Rectifier Manipulation | bigjppop | Tubelab | 1 | 16th January 2010 11:11 AM |
| simple se blowing rectifier and fuse | newtube | Tubes / Valves | 15 | 16th May 2009 10:54 PM |
| Tubelab Simple SE Rectifier Problem? | eddiemeddiem | Tubes / Valves | 45 | 21st June 2008 03:27 AM |
| simple transformer/rectifier problem... | maxw | Power Supplies | 7 | 10th August 2005 10:55 PM |
| Simple bridge rectifier question. | JoeBob | Everything Else | 51 | 15th February 2002 07:46 PM |
| Page generated in 0.12592 seconds (80.76% PHP - 19.24% MySQL) with 11 queries |
