Help : any tips to get +/-24v from SLA 48v Battery
Old 16th August 2010, 04:04 PM   #1
alamakazam is offline alamakazam  Singapore
Default Help : any tips to get +/-24v from SLA 48v Battery
Help : any tips to get +/-24v from SLA 48v Battery?
temporary using a centre tap 48v(4x12v) SLA battery, slight problem ... as they get unbalance voltage after some usage
need 100mA
Old 16th August 2010, 05:18 PM   #2
Dennis Hui is online now Dennis Hui  Canada
Something here may work for you:
Virtual Ground Circuits
Dennis
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 16th August 2010, 05:43 PM   #3
tried, the opamp operates +/1 15v max , I cant find any higher, or if anyone can introduce me 1
Tle2426 insufficient current...
Old 16th August 2010, 06:05 PM   #4
star882 is offline star882  United States
star882's Avatar
Charge pump made from discrete components.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 16th August 2010, 10:21 PM   #5
HRMMI is offline HRMMI  Croatia
Any OP amp can be used as voltage splitter. Including OPamp output amplifiers like LT1010. Any OPAMP can be powered over transistors with higher voltage then rated. But if you want to keep it simple try OPA 551 or OPA552 or OPA547 or OPA548 to make simple voltage splitter.
On picture you can see basic idea of powering OPamp with higher voltage then rated.
As it was mentioned, Charge Pump is also god option now days.
Old 17th August 2010, 03:23 AM   #6
gootee is offline gootee  United States
Look at the rail-splitter circuit in the LM675 datasheet at national.com and remember that you can use higher-voltage chipamps in place of the LM675, if necessary.
Old 17th August 2010, 03:54 AM   #7
stocktrader200 is offline stocktrader200  Canada
Measure the idle current draw from both rails (-+ 24v) and place an
equalization ballast resistor across the rail with lower draw so that both rails draw the same current from the batteries.
Old 17th August 2010, 04:16 AM   #8
cool ideas, I will try the LM675 for simplicity
for Charge Pump, does it mean a lower voltage input, and charge pump the splitted voltage output
Old 22nd August 2010, 06:17 AM   #9
Markus2006 is offline Markus2006  Poland
The easiest way to get virtual ground is to use the discrete rail splitter shown on the Vitrual Ground Circuits page (see link above). It uses only 8 discrete components. Depending on the output power requirements you may use more powerful transistors on the output. You can try e.g. TIP100/TIP105 (high power Darlingtons): http://www.fairchildsemi.com/ds/TI/TIP102.pdf . The only drawback is that some power will be dissipated by the transistors.
Mark
Old 26th August 2010, 06:59 PM   #10
TechGuy is offline TechGuy  United States
The potential issue I see with a Virtual ground circuit is power consumption. Since your running off battery I assume you want something pretty efficient. Plus a virtual ground will be about +24V which might present some challenges if you need to connect the devices chassis ground to Vbatt ground, or Earth Ground.
Use a Buck regulator but with two windings on the inductor. One winding is connected using the standard configuration for a buck regulator. The other would be used to generate the -24V.
Found this App note of the idea:
http://cds.linear.com/docs/Design%20Note/dn100.pdf
I bet this design would provide at least a 80% efficiency.Just use the LM2576HV or another simple switcher in place of the LT1376 since the LT1376 is limited to 26V input. The LM2576 "HV" design tops out at 60V. Since your load is very low go with a reasonably high inductance of around 100 uH to improve low current output efficiency. Note: note the dot on the inductor windings, The secondard is winding if flipped in relation to its connection to the switching diode (D1).
FWIW: you might be better off just buying a COTS DC to DC converter. a 48V to +/- 24V should be commonly available, and would have an effficient rating in the 92% to 96% range.
Help : any tips to get +/-24v from SLA 48v BatteryHide this!Advertise here!
+/-18V & +48V from a battery jeppix Power Supplies 24 27th November 2012 02:53 PM
Need help with SLA battery capacitor bank Doglover Power Supplies 9 20th June 2009 08:35 AM
Securing SLA Battery in Chassis??? HolyGhostFire20 Class D 1 4th August 2005 07:40 AM
SLA Battery Charger doomsweek Digital Source 2 21st November 2004 10:04 PM
Regulated SLA/battery supply? Nisbeth Solid State 14 15th February 2003 08:14 PM
Copyright ©1999-2017 diyAudio
