Go Back   Home > Forums > Amplifiers > Power Supplies
Old 7th August 2010, 07:10 PM   #1
Default Marantz 2215b Transformer and personal build
Hey all
I've gutted my old Marantz 2215b because certain parts have failed. I was wanting to use the transformer for my personal 200W amp design. Using personal schematics, I wired up the Marantz transformer with a and was able to achieve 48V center tapped. I need at least 63V. Does anyone know what the maximum DC voltage output of these transformers are? If voltage is higher, how do you go out about wiring it color wise to your hot/neutral/gnd etc. Any suggestions are greatly appreciated!
Old 8th August 2010, 02:03 PM   #2
Default 200 watts from Marantz 2215B transformer?
A quick search for the 2215B with Google shows that this amp was originally rated at at 15 watts per channel. I don't think you can really expect more out of it than that. More watts of output require higher rail voltage and higher current capabuility, which mean more steel and copper. If you can find a schematic for this amp it will show the various taps and windings, and the rail voltage that it was capable of.
Also, a word of caution. If a transformer has taps for multiple input voltages, for example 100V and 115V, it would not be safe to connect 115V to the 100V taps in an attempt to boost the secondary output voltage. The transformer will likely saturate, overheat and burn out.
Old 17th March 2011, 12:35 AM   #3
mr2racer's Avatar
Do you still have that transformer?
Marantz 8 clone build paulomacedo Tubes / Valves 5 15th January 2012 05:55 AM
marantz 1060 transformer naimgame Solid State 3 17th March 2011 09:37 PM
Marantz 8 B : Output Transformer refference Tubes / Valves 11 11th August 2010 08:51 PM
Build MARANTZ 7 line amp sjh327 Tubes / Valves 1 9th May 2010 04:06 PM
measuring a transformer Marantz 2245 naimgame Solid State 8 26th October 2005 08:27 PM
Page generated in 0.08471 seconds (71.87% PHP - 28.13% MySQL) with 10 queries
