Building a "stiff" supply and need some input...
Old 5th August 2010, 10:54 PM   #1
Adrculda is offline Adrculda  Canada
Send a message via MSN to Adrculda Send a message via Yahoo to Adrculda
Default Building a "stiff" supply and need some input...
Hey guys...
I'm at it again!!!
Here's the rough draft...
2 x 1KVA Antek AN-10440 Trafos 40VAC @ 25A in parallel + 12V 2A + 18V 2A.
Cap Bank will be 10 x 15000uF 63V Nichicon KMH's ( 5 per Rail - Bought 24 of them HERE )
This supply was designed around 2 x 1KVA Antek 10440 Toroids with 40V Secondaries tied in parallel for maximum current output...
Each Transformer will feed each board separately. As you have noticed the positive and negative side is identical besides the polarities on caps and bridges...
C1, C2, C3, C4, C5, C6, C7, C8 ( typo for C9 ) -> 0.1uF 400V Vishay Film Caps
C11, C12, C13, C14, C15 -> 15000uF 63V Nichicon KMH
C16 & C17 -> 1000uF 100V Nichicon FW
C20, C21, C22 -> 4700uF 35V Nichicon FW
C18 & C23 -> 150uF 63V Film EPCOS
C19 -> 15uF 100V Film EPCOS
Main rectifiers ( D1 ) are 2X Crydom M5060SB600
Secondary Bridges are standard 10A off the shelf units.
Driver Board will supplied separately from the output board at a higher voltage which can be selectable from SW1 and SW2 at 80VDC or 88VDC.
Also thinking C11 through C15 instead of 1 cap run 2 caps in series, but need to figure out the proper resistance to keep an equal voltage across both caps.
INPUT PLEASE !
Old 7th August 2010, 02:12 PM   #2
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Red on black? I can hardly read that...
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 8th August 2010, 12:42 AM   #3
Speedskater is offline Speedskater  United States
Speedskater's Avatar
It hurts my eyes.
Kevin
Old 8th August 2010, 08:13 PM   #4
Here's a better shot of the schematic...
Better ??
Old 8th August 2010, 10:45 PM   #5
what about being conventional and using black over white?
regards Andrew T.
Old 8th August 2010, 11:12 PM   #6
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
What is the application? Have you got a scope or spectrum analyser to help determine the correct inductor?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 8th August 2010, 11:52 PM   #7
Originally Posted by AndrewT
What about being conventional and using black over white?
I'm used to high contrast white on black as that's how my laptops desktop is set up and grew quite fond of it.
I don't at this time but will be trying to "simulate" circuit in LTSpice once i figure out how to use it.
Old 9th August 2010, 12:36 PM   #8
Sch3mat1c's Avatar
Well, it's visible now..
1. Why all the caps?
2. Why all the film caps?
3. Why four transformers? If you don't have enough VA capacity in one, I can understand that. Then,
4. Why four FWBs? You only need one for the main +/-63V rails, not two.
5. Why two extra transformers for the +/-80V supplies? How much current is required? Why not use a DC-DC converter to generate these, especially if they are low current?
6. You claim you need a "stiff" supply. Can you put a number on that? What impedance is actually required? If it's for an amplifier driving 4 ohm speakers, I'm guessing at most 10% of that, or under 0.4 ohms. Is that reasonable?
Tim
Old 9th August 2010, 12:50 PM   #9
bear is offline bear
expert in tautology
bear's Avatar
For a simulation there is a freeware that is designed for power supplies, I can't recall the name, but it should be easy enough to find.
The problem with doing a simulation will be getting all the paramaters for each component "correct". Raw capacitance, for example, will not tell you how one cap will perform over another - so in that case all the "extra" caps you have there will do nothing more than simulate like a single larger cap.
Also, the power supply will only show "issues" with a real world load - which is often a dynamic load. That is beyond the capabilities of LTSpice, afaik (well there may be some workarounds, but that is really complex).
If you want an exercise in simulation, start with simple, and work up. Also LTSpice afaik will not simulate a real-world transformer...
And a "stiff supply" is simply a low output Z supply WRT what it is loaded with. The same supply with a bigger load isn't quite so 'stiff' anymore??
_-_-bear
PS. what software are you using to draw the schematic btw??
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 9th August 2010, 03:39 PM   #10
Tim
1. For the most part they are there to filter out noise, and the other part is to store and dampen the large transient currents drawn by the amp.
2. Film caps are there to decouple the large electrolitics
See this THREAD for more details...
3&4. There are actually only 2 transformers but the program that i'm using only has a single secondary, hence why i used multiple. Also would like to have 25A of current on tap on each side of the "median". Since the 2 transformers are not center tapped its easier to build 2 mirrored supplies to deliver the needed voltage and current.
Also the start up will place large amounts of stress on the bridge rectifiers when the caps charge and maybe a peak of 200-300A flowing through the rectifiers upon the charge of the caps. By using 2 rectifiers the current draw will be theoretically half of what i would be drawing across 2.
5. There is no extra transformers, they are meerly a second set of secondaries of each transformer. They will be used as the supply the LME49810's and at most 1A will be needed there.
6. The amplifier itself uses 8 Complimentary pairs of NJL4302DG & NJL4281DG.
Its basicly a current dumping amplifier and hopeing that it could drive loads as difficult as 0.5Ohms ( not that i will ever use it, but why not overbuild things to be able to withstand abuse from reactive and capacitive loads )
Building a "stiff" supply and need some input...Hide this!Advertise here!
What Does Fostex "Rated Input" and "Music Power" mark02131 Full Range 5 13th October 2012 05:18 AM
Ridiculously "stiff" sub !! what is the point? JinMTVT Subwoofers 95 6th August 2010 03:32 AM
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
Building a 2.1 system out of a 48"x96" sheet of 3/4" MDF 454Casull Multi-Way 0 18th November 2008 02:19 AM
Fostex "rated input" and "music power" hugz Full Range 12 16th March 2006 04:33 PM
Copyright ©1999-2017 diyAudio
