Hello everybody,
I am making a High negative voltage supply for a differential stage in a tube amplifier I am constructing. I don't need more than -120v. I stumbled across this gem http://www.national.com/an/LB/LB-47.pdf Basically what I want to do is change the LM317 to an LM337. I was thinking the following steps would be needed 1. Switch NPN transistors to PNP 2. Reverse all Diodes 3. Reverse any electrolytic capacitors. Am I forgetting anything? thanks -Moose |
#2 |
an isolated supply can have any output voltage, it is effectively floating.
Connect one side of the supply to a reference, let's use Zero Volts = Ground, then the other voltage is referred to that. If you have an isolated +ve regulator with 120V between the two outputs, then either output can be connected to the reference. Connect the more -ve output to Zero Volts and you have 0,120V supply Connect the more +ve output to Zero Volts and you have 0, -120V supply. This will work just as well as your proposal, without having to worry about whether it might work as modified.
regards Andrew T. |
#3 |
I was thinking about that as well, Just connect the output to some -1xx voltage and use the regulator backwards? sounds even easier
Thanks |
#4 |
that's not quite what I said.
Connect one output pole to your voltage reference and the regulator sends the other output pole voltage at it's regulated voltage. eg. build a 0,+120Vdc regulated supply. Connect 0V output to Zero Volts and the other output will sit at +120Vdc. Instead connect +120Vdc output to Zero Volts and the other output will sit at -120Vdc. There is nothing fitted "backwards". On the other hand you could have a 0, +60Vdc supply with 0 connected to Zero Volts. The other pole sits at +60Vdc. Now connect the 0 of your 120V supply to the existing +60Vdc and the other output of the 120V supply will sit at +180Vdc (+60V +120V = 180V)
regards Andrew T. |
| Adjustable voltage-mode smps | zkaiser | Power Supplies | 6 | 3rd December 2010 12:25 PM |
| adjustable voltage regs compatability | KevinLee | Parts | 1 | 16th December 2008 07:18 PM |
| LM385 Adjustable voltage ref. diode as LED bias? | mus | Tubes / Valves | 2 | 30th March 2007 04:27 AM |
| Adjustable regulated power supply | Ford_V6 | Solid State | 2 | 1st April 2003 05:03 PM |
| Adjustable power supply questions | rendisha | Parts | 27 | 17th January 2003 06:23 PM |
| Page generated in 0.07492 seconds (71.13% PHP - 28.87% MySQL) with 10 queries |
