Hi...
I am working on design where i need to select an optocoupler. This should operate at voltage as high as 60V. So what parameter should i consider when selecting it. Is the collector base voltage to be considered or collector emitter voltage to be considered. I have gone thorugh MCT-2E's datasheet. Is it appropriate to use. Please suggest Vasu |
#2 |
Collector-emitter voltage is what matters, many optos don't even expose the base and just bias it internally. The MCT-2E will not work in your application.
"Audio grade" components simply means that they failed at a more critical job. |
#3 |
thank you...
any suggestions, for the same specs vasu |
| Analog amp with optocoupler | lumanauw | Solid State | 2 | 12th August 2008 02:36 AM |
| HCPL3100 Optocoupler | Gold_xyz | Parts | 1 | 18th November 2006 06:38 PM |
| FET optocoupler as VR | Leolabs | Solid State | 2 | 24th September 2006 07:48 AM |
| high speed optocoupler | djdamix | Class D | 5 | 21st April 2005 02:54 PM |
| Page generated in 0.08422 seconds (75.39% PHP - 24.61% MySQL) with 10 queries |
