Go Back   Home > Forums > Amplifiers > Power Supplies
Old 24th July 2010, 11:36 PM   #1
jetbat is offline jetbat  United States
Default Help with rectifier circuit
Hi, I am building a power supply for a microphone preamp, +24V, with phantom power, +48V. The +48V is going to use less then 10 mA and the +24V will use around 105mA. I've attached a picture of two rectifier circuits I am thinking about.
Are there any problems with either circuit and which one, if any, has advantages over the other?
Scott
Old 25th July 2010, 01:21 AM   #2
nigelwright7557's Avatar
At a quick glance.
The first one wont work as you need a common ground.
Connecting zero volts on one to zero volts on the other will blow up the bridge.
Or, I could be wrong.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 25th July 2010, 04:24 PM   #3
Thanks for the reply. As you can see I am still new to this. I have two more circuits.
The first is with a voltage doubler. I'm not sure if the grounds can be tied together like this. Also does the unloaded output voltage of a voltage doubler = Vin*1.41 the same as a bridge rectifier.
The second one is suppose to work but I just need conformation of this.
Scott
Old 25th July 2010, 04:56 PM   #4
Scott
You cant tie the grounds together on the first one it would blow the rectifier.
Old 27th July 2010, 02:06 AM   #5
Is there any problem that anyone can see with the second circuit in the second picture?
Old 27th July 2010, 04:40 AM   #6
RJM1 is offline RJM1  United States
The second one will work an give you +24 and +48V.
TDA7293 circuit = half wave rectifier booj Chip Amps 8 18th January 2010 08:51 AM
converting tube rectifier to solid state rectifier. tubo Tubes / Valves 26 24th December 2009 12:12 AM
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
short-circuit rectifier EZ80 ! jpweaner2 Tubes / Valves 4 6th May 2007 04:48 PM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Page generated in 0.08746 seconds (71.88% PHP - 28.12% MySQL) with 11 queries
