Transformer soft-start with relays Transformer soft-start with relays - Page 4 - diyAudio
Old 14th October 2010, 10:34 AM   #31
Originally Posted by metalsculptor View Post
It works fine I posted examples in a prior thread, I had the problem that Andrew T mentioned once because the series resistor was too high, aim for 5x the full load current at start for a soft start.
I want to use a close rated fuse in the primary feed. I find I can get away with a fuse ~=maximum rated current if the soft start resistor limits the peak current to ~3X maximum rated current.
The lower the required fuse rating the worse the risk of the relay not pulling in.
This problem goes away if a real timer circuit is adopted.
Metal,
you are right the Zener makes the non activation of the relay much worse in low voltage conditions.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 14th October 2010, 11:44 AM   #32
metalsculptor is offline metalsculptor  Australia
I tend to use circuit breakers, which have no problem starting a 5x rated load but trip a bit slower than a fuse, the reasoning being that it is difficult to protect semiconductors with a fuse, so protecting the rest of the system is the primary goal and a bit of surge rating is quite handy for testing, 2x overload for a few minutes doesn't bother a robust power supply. The majority of industrial control power supplies in Australia are protected by cheap DIN rail mounted MCB's which for around A$6 are quite competitive with fuses. The physical size of an MCB compared to a 3AG fuse can be problem for a small PSU.
Transformer soft-start with relaysHide this!Advertise here!
Soft-start circuit with no relays and no aux. transformers Eva Power Supplies 102 29th March 2015 11:25 PM
Soft Start again marsheng Power Supplies 0 29th June 2010 10:09 AM
Need a soft start? maxpou Solid State 19 18th April 2007 09:23 PM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
Copyright 1999-2017 diyAudio
