needing some ideas for a radio controlled car re capacitors!!
Old 26th July 2010, 10:08 AM   #31
ThyDntWntMusic is offline ThyDntWntMusic  Australia
Originally Posted by godfrey View Post
I thought you were going for the 63V caps?
Lower ESR and higher ripple current than the 25V ones.
no?
I linked to, and gave specs for 25volt ones.
I wasn't sure what you were saying about 63volt caps.
Old 26th July 2010, 10:24 AM   #32
godfrey is offline godfrey  South Africa
Huh?
From Jaycar:
Capacitor Electrolytic 220uF 25V 105C L/ESR - Jaycar Electronics
Impedance: 0.13
Ripple Current mA rms: 640
Capacitor Electrolytic 220uF 35V 105C L/ESR - Jaycar Electronics
Impedance: 0.09
Ripple Current mA rms: 840
Capacitor Electrolytic 220uF 63V 105C L/ESR - Jaycar Electronics
Impedance: 0.060
Ripple Current mA rms: 1220
I thought the specs you gave looked like that last one.
The 1000uF 35V one is about twice as good, but also twice the price.
It would be nice to know what size they all are...
Old 26th July 2010, 10:27 AM   #33
Huh?
From Jaycar:
Impedance: 0.13
Impedance: 0.09
Impedance: 0.060
which is why I wasn't going to use 220uF, 35volt,
but rather 470uF, 25volt.
Old 26th July 2010, 10:37 AM   #34
Magura is offline Magura  Denmark
Magura's Avatar
Have you checked that the caps are in the right way around?
Such heat build up in the caps, sounds like either the caps are dead, or wrong polarization.
Any junk cap should be able to handle that little bit of ripple.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 26th July 2010, 10:39 AM   #35
Magura
if they were wrong, they would have exploded a very long time ago!
Old 26th July 2010, 10:43 AM   #36
Magura's Avatar
Not necessarily, they can survive quite some time if they are not loaded real hard, and the voltage is much lower than the rating.
Instead of wild guessing, how about you actually measure if they are in the right way?
After that, take one out and measure if it's in reasonable condition.
You have had quite a few suggestions so far, but have failed to take any action.
None of the suggestions made, would take more than 15 minutes to test.
Either take some action, or quit wasting our time.
Magura
Old 26th July 2010, 10:45 AM   #37
no, if they were around the wrong way they would have exploded a very long time ago...
Old 26th July 2010, 10:50 AM   #38
Ah, OK. There's no specs for that one online.
For 470uF, the 35V and 63V ones have better specs, but I suppose you have to consider what fits too.
Anyway, good luck with it!
Edit: sorry, this was a reply to post 38.
Old 26th July 2010, 10:51 AM   #39
yes, the 25volt, 470uF are the same dimensions as the 35v 220uF.
plus, the 150amp esc I have only uses 25volt capacitors, and is rated for the same voltage.
I'm quite sure that 25volt caps is enough for 17volts
Old 28th July 2010, 09:04 PM   #40
oh, yeah, I haven't bothered replacing the capacitors yet as the motor failed
needing some ideas for a radio controlled car re capacitors!!Hide this!Advertise here!
newbie, needing help with vintage capacitors? Joshua_j Parts 8 10th April 2009 06:32 PM
Audio [Radio] Amplifier Ideas Needed audiohobby Solid State 0 27th February 2009 01:21 PM
8 track car radio EmergencyDpt Car Audio 0 4th September 2008 02:34 AM
car radio antenna petercampusa Car Audio 1 29th April 2006 08:21 AM
Car Radio - Power comes on and off apiano29 Car Audio 0 25th June 2003 04:50 PM
