HI..
I have designed a flyback which takes in upto 60 volt for a dual output of 12V. It is a self oscillating flyback. I have used transistorised contro circuit. But i have been facing comstant failures, when the circuit is put for use. I have attched the schematic. Please suggest me the loop holes in the design. vasu |
#2 |
Transformer ratio?
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#3 |
Is this a home-brew circuit??
How about the switch transistor, Q8. Is this supposed to be a small signal transistor?? I would have used a FET instead. What kind of failures do you see? Will it not start up, or does it burn the transistors?? |
#4 |
Hi...
The problem is with the reliability of design. I am using BU-508 at Q8, and BD-139 at q7. As such the circuit works fine and is able to withstand a load upto 600-700mA. But Q7 tends to heat up pretty soon. And fails. Why do you recommened FET? Vasu |
#5 |
The transformer is 38 turns primary.
I &II secondary-25 turns and III secondary 32 turns. I would also like to know how is the switching of Q7 controlled thank you for reading me Vasu |
#6 |
what is..BC565?? Q7 conduction...at inverse circumstance?? Regards |
#7 |
collector of BD139 can not direct on diode,(high current pass when it conduce (this is a mistake)
Regards |
#8 | |
have you tried changing? Regards |
#9 |
yes
i changed it to BU-508. It did help, but ocassionaly it still fails. And Bd139 heats up too. Why is the direct connection to D17 wrong. And how would adding two 470E help. Also explain me the switching of bd-139. Thank you for your suggestions and guidance. i m new to power supplies. vasu |
#10 |
I think that you not have try with my correction (cut collector from 2,7K) and add 2x470R. with this modify is not possible heat up BD139. Not have sense high current of collector (connect direct d17) when it change work point of BU508. (TL431 driving BD139 for regulate Out) it is a "Pseudo" pwm way . Also not clare in this scheme phase of link feedback (in scheme is inverse). BTW. Normally I used BC337 instead of BD139, it work good. (then I.C. current is low) Regards |
| Class D Design Issues | Variac | Class D | 70 | 11th April 2012 02:05 AM |
| Flyback design for preamp | TomSSS | Power Supplies | 0 | 11th November 2006 11:53 PM |
| Page generated in 0.10310 seconds (85.72% PHP - 14.28% MySQL) with 11 queries |
