Hi guys!
Can anyone clear about voltage rating of diode? I want to make bridge rectifier using Vishay's 60EPU02, it seems that this one is very good for audio and also I can grab these for a pretty good price, but I doubt in one parameter - voltage rating of this diode is only 200, is it still ok for my psu? or I need more 400 or 600? I will use 50-0-50 500VA transformer with C filter. Thanks to all! MD
#2 |
200 volts is perfectly fine. Your transformer is 2x 50v AC RMS thus 141.4 volts peak. That's still quite a bit under 200v.
If your trafo were 2x 70v or higher it would require 400v diodes, but like it is now you'll be fine.
"Audio grade" components simply means that they failed at a more critical job. |
#3 |
Thank you! I also thought so, but it seems that diode will work at its limit, because, if I understanding right, 200V is a peak rating of diode, but its RMS voltage will be 200*0.7=140, so seems it will work just near the limit.
MD |
| Using a zener diode as voltage reference with variable voltage regulators | ginetto61 | Power Supplies | 14 | 20th September 2009 01:55 PM |
| BYV79E as rectifier diode | tubee | Solid State | 5 | 18th June 2008 02:45 PM |
| diode rectifier ratings | redrabbit | Power Supplies | 8 | 13th November 2006 05:33 AM |
| replacing 2-diode rectifier with a bridge and other PSU upgrades for old reciever | bikehorn | Power Supplies | 12 | 5th April 2006 08:55 AM |
| Make things clear about PSU | Guss | Chip Amps | 4 | 3rd February 2004 11:13 AM |
| Page generated in 0.07067 seconds (69.27% PHP - 30.73% MySQL) with 10 queries |
