I need a PSU for 6 LM3886's
Old 16th July 2010, 11:19 AM   #1
Boscoe is offline Boscoe  United Kingdom
Default I need a PSU for 6 LM3886's
I need a PSU to power two of THESE for a stereo amplifier, it requires -35,0,35 volts so can I just use this
and use a bigger transformer and bridge rectifiers? And do I bridge the PGND?
Boscoe
Old 16th July 2010, 01:44 PM   #2
Redshift187 is offline Redshift187  Canada
That's a very common power supply design, but it depends on the actual board design.
How much current do you need?
Is there room for heatsinks on the diodes?
Are the traces big enough?
Of course if you put it all together "point to point", with thick wires and heatsinked rectifiers, it's a non-issue. Your ripple will be determined by how much current you draw vs how much capacitance you have, you're going to want quite a bit of capacitance.
Tyler
Old 16th July 2010, 01:51 PM   #3
I can't find anywhere how much it pulls for one or for three on the amp i'm gettin.
Old 16th July 2010, 01:56 PM   #4
Found a source I'm going to use a 500VA transformer so could I just up everything in this schematic?
Old 16th July 2010, 02:02 PM   #5
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
If you're interested in getting the best sound, the diodes would benefit from having RC snubbers across each (say 10nF and 100R). And the snubber on the output doesn't need to have a 2W resistor at all. Carlos eventually modified the cap too, to 1.5nF- 3.3nF and the resistor down to 0.47R
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 16th July 2010, 02:07 PM   #6
R.I.P.
the peak current from a 3886 is between 7Apk and 11.5Apk when cold.
6off cold 3886, all at the same maximum peak output, could be ~70Apk current draw from the PSU and decoupling.
regards Andrew T.
Old 16th July 2010, 02:13 PM   #7
You sayin to make a ~2000W PSU!????
Old 16th July 2010, 02:14 PM   #8
abraxalito's Avatar
Yes - might be worth investigating making slightly better use of the power supply by running 3 of the chips with an inverted signal (or making them inverting). Peak currents are usually rather asymmetric so by having half the amps running inverted both capacitors get to provide the peak current rather than just one.
Old 16th July 2010, 02:44 PM   #9
Not necessarily. Consider making a separate power supply for each channel. While it'll cost a bit more (depending on transformer costs), you won't have to deal with large amounts of power in one place.
Also, what impedance are the speakers you are driving with this amp?
Tyler
Old 16th July 2010, 02:58 PM   #10
abraxalito's Avatar
It will cost quite a bit more than a single unit. Then the inrush current from six power supplies all being switched on together won't be too pretty The advantage I can see from doing all monoblocks is it makes the grounding easier. But I think it won't give such a good bang-for-the-buck as the single higher power supply. The 2kW figure is only extreme peaks, assuming that all channels receive the same peaking signal in phase. Seems jolly unlikely to happen in practice.
I need a PSU for 6 LM3886'sHide this!Advertise here!
350W Power Amp with LM3886'S zafira1981 Chip Amps 44 2nd February 2008 06:00 AM
need directions for 8 channel amp with LM3886's Diy_Ambitious Chip Amps 9 18th March 2005 11:11 AM
Wiring 2 LM3886's soundNERD Chip Amps 2 29th November 2003 12:00 PM
Paralleling LM3886's-the right way jan.didden Solid State 15 4th November 2003 11:59 AM
Curious, had a 2 channel car amp burn up with two lm3886's ShowNuff99 Chip Amps 1 19th October 2003 05:38 PM
