Which do you prefer?
Is there a better option? I want to run 2 of hifimedy tk250 boards off it. Cheers |
#2 |
As a side note. The connexelectronic is available as 27v and the meanwell
is only available as a 24v. I also know the switching frequency is 100khz on the meanwell but not sure what it is for the connex unit. An obvious difference is the meanwell has PFC and world wide power supply 90-260v input. |
#3 |
HI Meanwell !
I have used in dac and class D,very fine after 3year
Sic58
#4 |
There are a lot people who really rate the Meanwell smps's!
i have not found any comparison reviews between the 2 though? The Meanwell USD350 is a lot more expensive at £132 here in the uk as apposed to £80 for the Connex A350SMPS unit? Yes the Meanwell has the extras of wide input voltage and PFC but these do not necessarily mean that they sound better which is my main concern. Also reliability is an issue to consider carefully though! |
#5 |
If the universal mains voltage is an important issue, you might consider the SMPS250. Connexelectronic
this is able to deliver 250W continuous from 90V AC up to 250V AC, and up to 400W peak power. if the power is still not enough, you can consider the SMPS500R, Connexelectronic 500W continuous and 650W peak. it uses resonant topology, has very low EMI and high efficiency. one important question: do you need differential voltage or single rail voltage ?
www.connexelectronic.com complete assembled amplifier and SMPS |
#6 |
I guess we shall have to test both.
I've sent you an email Cristi regarding a couple of things. Kindest Regards |
#7 |
I have used Meanwell PSU's for industrial applications and they are very reliable.
| TDA8920 TDA8924 By Connexelectronic, Opinions Please. | cirrus18 | Class D | 55 | 7th May 2013 02:14 PM |
| meanwell ??? | jrcanoe | Power Supplies | 1 | 6th April 2010 07:12 PM |
| Connexelectronic amp modules listening comparisons? | sendler | Chip Amps | 1 | 25th September 2009 10:32 PM |
| using meanwell SMPS S-350 as power amp PSU? | lhgin | Power Supplies | 2 | 18th August 2009 10:36 AM |
| Connexelectronic TA2022 amplifier with FE167E (94dB/w/m) opinion? | lhgin | Class D | 5 | 3rd August 2009 05:34 AM |
