possible transformer VA ratings
Old 25th June 2010, 04:19 PM   #1
xeclipse is offline xeclipse  Kenya
Location: Where the world's best tea come from:Kericho Kenya
Default possible transformer VA ratings
I just purchased a transformer from a pawn shop with the following writings:81-AA2-608-018.
It was rescued from unidentified 'ancient' pioneer amp,probably stereo.It has two secondary windings (70 and 22 Vac) each with center tap.What is the possible VA ratings of the 70 Vac winding?
if there are no sparks,it probably doesn't work!
Old 25th June 2010, 04:23 PM   #2
R.I.P.
what is the size and weight of the transformer?
What are the thicknesses of the primary and secondary windings.
regards Andrew T.
Old 25th June 2010, 05:18 PM   #3
bob91343 is offline bob91343  United States
You could spend a lot of time looking at various Pioneer service manuals to find which model used that unit. Then of course you'd have pretty much all the information you seek.
Another method is to weigh the transformer and compare that to the weight of known transformers in various catalogs. That will give you the approximate amount of power but you still won't know the capabilities of each winding. So you'd have to disassemble somewhat to see the wire size and calculate current capacity on the basis of perhaps 600 circular mils per Ampere.
Old 26th June 2010, 06:41 AM   #4
the core measures 2.75 * 3.25 * 2.75 and weighs over 3.5 kgs(7.7 pounds).
I am not sure of the wire size but the 44 Vac windings are thiner,i guess it was meant for an op amp.
Old 26th June 2010, 08:47 AM   #5
R.I.P.
now look up a few manufacturers catalogues and find the average weights of 100VA EI and 200VA EI, etc.
regards Andrew T.
possible transformer VA ratingsHide this!Advertise here!
Transformer Ratings jt1 Tubes / Valves 7 31st March 2010 09:36 AM
Transformer VA versus output power VA nigelwright7557 Solid State 8 18th May 2008 02:57 PM
va ratings for ucd180 snkby Class D 4 25th March 2006 12:31 AM
Transformer ratings??? AR1 Power Supplies 2 2nd May 2005 07:02 PM
transformer VA pjanda1 Chip Amps 16 20th March 2005 01:11 AM
