Go Back   Home > Forums > Amplifiers > Power Supplies
Old 19th June 2010, 10:05 AM   #1
Default Quick question on connecting this power supply
Hi I bought this acopian linear power supply but Im confused as to which is the positive and negative for the AC input, I coulnt find any info of this on their site, I included picture of it below. thanks
Old 19th June 2010, 10:24 AM   #2
EBM_dude's Avatar
AC per definition has no positive or negative terminal... Or what dou you mean?
Old 19th June 2010, 10:40 AM   #3
Hi I meant hot and neutral. I have to connect an AC power cable to it I would like to know to which AC input the hot wire would go and to which the neutral would go on the power supply. Theres two on the power supply L AC and N AC
Old 19th June 2010, 10:44 AM   #4
EBM_dude's Avatar
It doesn't really matter, as soon as you plug in the plug turned around 180 degrees, you'll be off again. If you really want to do this, then take a screwdriver with a neon lamp inside (dunno what they'Re called in English) and test the socket. The wire that makes the lamp glow is L, the one that doesn't is N IIRC.
http://upload.wikimedia.org/wikipedi...ningzoeker.jpg
Phase testing thingie
Old 19th June 2010, 10:46 AM   #5
AP2 is offline AP2  Italy
N= Neutral
L= Phase
This is ac input.
what is the input voltage? (I think 110VAC)
DC voltage out? current output?
Old 19th June 2010, 10:46 AM   #6
Mooly's Avatar
And don't forget the mains safety ground... careless wiring on this could be dangerous as it's all open to touch.
Hot is Live or L ,and neutral is neutral N
A simulation free zone. Design it, build it, test it.
Old 19th June 2010, 11:38 AM   #7
so L=Live (hot) and N=neutral that makes sense lol. So if I were to put neutral in the L input and the hot in the N input what would happen? I imagine the fuse would just blow, not that I'm going to do it but I think it would be good to know.
Mooly I definitely wont forget to connect the ground .
Old 19th June 2010, 11:49 AM   #8
Not exist a psu with dedicate one pole at "L" or "N".
some industrial power supply dedicate line pole.(only for legislation)
not blow fuse if you connect this.
both lines input have necessary ISO to GND(ground)
Old 19th June 2010, 04:19 PM   #9
Mooly's Avatar
It would work just the same if you swapped the L and N, however reversed polarity can be dangerous (on anything) for anyone working internally on the equipment.
Think about a table lamp with a single pole switch... if you reverse the polarity the lamp socket is always live, even though the lamp appears to function normally.
Old 19th June 2010, 05:04 PM   #10
gootee is offline gootee  United States
L = LINE (aka "Hot")
N = NEUTRAL
In the USA at least, LINE/Hot is the smaller of the two prongs on polarized AC wall plugs.
They wouldn't specify which was which if it didn't matter. Even if it only matters for legal purposes, there is possibly a good reason for it. So it's safer to not ignore it.
PC Power Supply Mod - Quick question for someone with an EE etc. calee4nyaboy Parts 7 31st December 2009 05:10 PM
connecting AC-DC power supply gychang Class D 8 9th July 2009 11:15 PM
connecting a switch mode power supply peace brainerd Parts 5 24th April 2008 11:32 PM
Just a quick power supply capacitance question markiemrboo Chip Amps 137 14th February 2007 04:53 PM
quick Q on power supply caps theChris Parts 3 5th November 2003 05:50 AM
Page generated in 0.11843 seconds (75.62% PHP - 24.38% MySQL) with 10 queries
