I amp building a pair of ESP P101 Mosfet amps. The planned outout power will be ~150W per channel. The design note sugest the supply transformer should be 200VA per amp. So 400VA for the pair.
I have an opertunity to purchace a toroidial unit with two secondaries that are 38V @ 15Amps = 570VA x 2 = 1140VA. This ia ~ 3x what I need. The unit has an internal electrostatic shield and the price is very good ($50) Any issues? I read somwhere that excess transformer capacity increases ripple current. I don't understand how. Is this a concern in my situation? PS: Later I am planning to build another amp pair for biamp setup. So in that case perhaps this big transformer would be ideal? |
#2 |
I am no expert, but a larger capacity transformer should not cause extra ripple. Excess ripple is generally caused by not enough microfarads in the power supply. Modern power amplifiers have lots of power supply rejection and moderate ripple should not be a problem. All power supplies except for regulated ones have ripple. Regulated ones will have a lot less but it still will be there to some extent. 76Vct is cutting it close if you want to get 150 RMS @ 8 ohms. You need around 35 volts rms to get 150 watts rms @ 8 ohms ie (35*35)/8=153. (35vrms * 1.41)=49 peak . Add a few volts for VCE losses Re losses fuse loss etc ripple, power supply sag and you will end up needing around +/- 65-70 volts DC. your tranny will give you a ball park figure of around 53-55 volts depending on line voltage, diode losses etc. If your target is 150 watts rms @ 4 ohms, no problemo. If you have an unshielded transformer keep the signal lines away from the tranny and all should be fine. There are bigger things to worry about. Remember most class AB amps are around 50 -60% efficient so multiply your desired out put by 2 per channel to get your ideal tranny rating. Hammond a transformer manufacturer used to rate their tranniess at 200% for a given period of time and 100% for almost ever. $50 is a great price.
#3 |
using a 230:40+40Vac transformer run on 240Vac, I got >170W into 8r0
150W should be possible from 38+38Vac, but it will depend on the available mains voltage.
regards Andrew T. |
#4 |
you may want some sort of inrush current control at that power level, even more so with the oversize xfmr
#5 |
For those interested. There five more availble on ebay at http://cgi.ebay.com/ws/eBayISAPI.dll...m=330401468912 I got specs from Noratel UK- I list the basics below and i've attached the datasheet. Four Primary windings 2 x 100V 2 x 15V Four Secondary’s (all non inverting) 2 x 38V @ 15 Amps (39.1V Unloaded) 2 x 36V @ 2 Amps (37.5V Unloaded) One electrostatics shield (Yellow Wire) - soul-wind |
#6 | |
space |
| looking for 18v dc tranformer | jtktam | Swap Meet | 2 | 26th January 2010 11:33 PM |
| Step down tranformer | jkeny | Everything Else | 2 | 18th October 2005 12:14 AM |
| Tranformer question | CPX | Parts | 3 | 7th February 2005 07:44 PM |
| Can someone explain this tranformer? | dvdwmth | Chip Amps | 5 | 9th September 2004 08:03 AM |
| isolation tranformer with / without filter | ackcheng | Parts | 10 | 21st June 2004 01:25 PM |
| Page generated in 0.10369 seconds (72.97% PHP - 27.03% MySQL) with 11 queries |
