Hello
i am building a tube amp, where i need around 15A for the heaters, which run at 6.3V.. but.. the power trafo i have, is abit old, so it was made for 220V, but i have 230-240V in my outlet, so all the outputs are just abit higher then what is printed on the trafo. so now i have a 7Vac where i need a 6.3Vac. i could use a resistor in series.. but that would have to disipate 10W.... could maybe do something with some diodes.. but is there diodes that can take the current, and in a package that is suitable for some cooling? the power supply will be powering 2 seperate monobloks, so would be nice if the voltage wasnt load dependent which it will be with the resistor.. i am thinking the resistor is the best ideer... but there could very well be a super simple ideer i just havent thought of, so i though i would ask in here :-) regards Jens Last edited by heinrichs; 17th June 2010 at 06:50 AM. |
#2 |
Have you tested the voltage with a load that draws 15A?
#3 |
that is correct ...voltage will drop no matter what with 15A load .... even possible that it drops more than needed ....
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#4 |
Put two antiparallel diodes in series. This will reduce 0.6 volts
Gajanan |
#5 |
offcourse... just didnt think about that... normally i use switchmodes for everything....
gonna do some measurements when i get home from work today, thanks :-) #4 just have to be some pretty big diodes... but should work though.. |
#6 |
The diodes will work, but they will dissipate exactly the same power as the resistor.
In addition, they will generate severe harmonics and switching noise. Of course, if your wiring is absolutely perfect, this doesnt matter, but..... If you want a solution that is both non-dissipative and "quiet", you could use a series inductor: in this case, 150µH would do the trick (it obviously has to be rated for 15A). It will not only adjust the voltage to the correct level, but also somewhat soften the cold start, and improve the noise filtering. |
#7 |
connect up your 15A worth of heaters and measure the voltage across the heater pins, before you do anything else.
If you want to draw a continuous 15Aac from your transformer, the secondary winding must be rated >=15Aac and preferably >=30Aac, (200VA). What size is your transformer?
regards Andrew T. |
#8 |
I ended up puttig my heaters in paralel 2 by 2, since i have multiple 6.3v outputs on my trafo, so i could connect them making 14Vac.
and then i found some 160µH 6A inducters, and 2 of them in series for each mono blok does the trick. thank you all for your help. |
| 12V AC to 6.3v DC simple supply for idiots | DrewP | Tubes / Valves | 12 | 14th September 2009 02:06 AM |
| How easy is it to convert from 110V AC to 240V AC? | spikeyfaz | Analog Line Level | 19 | 26th December 2007 07:14 PM |
| WTB: Analog AC Ammeter - AC Voltmeter - Panel Mount | dBfreak | Swap Meet | 1 | 16th March 2007 10:41 PM |
| PS question- Need to get 20V AC from 60V AC - w/o Trafo | lgreen | Pass Labs | 9 | 2nd January 2004 10:31 AM |
| HUBBELL IG3800 clones? AC sockets /AC wire | jasonruiz | Parts | 5 | 25th April 2003 10:21 PM |
| Page generated in 0.09953 seconds (77.18% PHP - 22.82% MySQL) with 10 queries |
