I'm planning on building a basic amp using an LM3875 kit from audiosector, and pulled a transformer from an old powered subwoofer for the project, as pictured below. I'm picking all this up as I go along, so I was wondering if anyone could tell me if this is a suitable transformer, or if I should keep looking. Based on what I've read, for my 8ohm speakers around 23V AC would be suitable, so I'm guessing I can use a red and white in series to achieve this ?! Thanks very much for the help everyone! caleb ![]()
#2 |
Your question is not very clear. What DC voltage do you want after the rectifiers?
#3 |
Sorry, as I mentioned, I'm new to this
I think anywhere from 28 to 35 V DC is what I'm after. |
#4 |
you could use the two 15.8Vac wires as a temporary supply. ~66VA This will give ~+-20Vdc after passing through a single bridge rectifier and into the dual smoothing capacitors. If using 8ohm speaker. Look for a 20+20Vac to 26+26Vac dual secondary transformer or a centre tapped 40Vac to 52vac transformer. For a single channel 100VA to 160VA will work reasonably well. For a two channel, 120VA to 250VA will work well.
regards Andrew T. |
#5 | |
#6 |
few consequences.
It just sounds better with slightly bigger than adequate transformer.
regards Andrew T. |
#7 |
| Modulation transformer for a driver transformer? | ironradio | Tubes / Valves | 6 | 28th December 2008 05:05 PM |
| Using isolation transformer as a PSU transformer??? | Yaho | Tubes / Valves | 10 | 27th February 2008 04:16 AM |
| filament transformer vs plate transformer | contaxchen | Tubes / Valves | 10 | 14th January 2005 10:43 AM |
| toroid Transformer as power Transformer for tube | tone | Tubes / Valves | 7 | 11th February 2003 08:57 AM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 04:36 AM |
| Page generated in 0.08637 seconds (85.51% PHP - 14.49% MySQL) with 10 queries |
