So I'm working on a project to convert my old solid state guitar practice amp into a simple single-ended tube amp. I'm working on the power supply and it's getting there. I got the filaments going but now I need my B+ supply.
It's a beginners project and I'm looking to spend as little as possible on it. I'd like to do it with parts I have if possible rather than buy new components (just for fun - as a challenge I guess) so I know I'm going to have Macgruber some things and I don't mind that. I'm doing it for fun more than for sound. I've seen other projects where people used two ordinary step-down transformers hooked up secondary to secondary to get a suitable voltage for the tubes. I have two transformers I want to use but I've run into problems. The first transformer puts out 32v unloaded (sags to about 27v under load). It's center tapped 16-0-16. The other isn't tapped and puts on 12v on the secondary. When I hooked them up secondary to secondary (outer wires on the first transformer to the secondary of the second) I get 160v for a few seconds until it drops off. The first transformer starts getting warm at that point so I guess I'm saturating the core? Flux density is highest when there is no load on the transformer so I figure it must be working the first transformer pretty hard? I unhooked the second transformer and the first works fine so I didn't fry it. I switched the wires thinking they might be out of phase but that didn't work out. I'm new at this and sort of learning as I go and inductors and transformers are a complex subject so questions: -Do the two transformers have to have the same rated primary and secondary voltages to work in this configuration? -Is there a way to make this work? The amp will have a standby switch and I haven't tested it with a dummy load yet. Will it still do this once I hook up a load to the second transformer? -If this just isn't going to work where can I find some cheap iron? I seem people on here score some nice stuff from time to time. Ebay is cheap until you factor in shipping. Is there some easy to find devices that have a good transformer I can salvage? I'm shooting for a plate voltage of ~250vdc so something that puts out around 180vac would be ideal I think. Thanks in advance! |
#2 |
If you are applying 16 VAC to the 12 volt winding, the second transformer will probably saturate. if you apply 32 volts to it, it will surely saturate.
#3 |
Banned
It's usual to plan the voltage scheme and current requirements before you start with a project like this, and pick transformers that will both allow you to develop a heater supply and have sufficient current for the HT.
What is your local mains voltage? w |
#4 | |
Obviously I'm a noob and sort of figuring things out as I go. But it's been fun so far. |
| Some questions about transformer | LosNir | Power Supplies | 2 | 23rd March 2010 04:18 AM |
| Transformer questions | synthius | Chip Amps | 18 | 10th December 2007 10:28 AM |
| transformer questions | woodturner-fran | Tubes / Valves | 9 | 12th March 2007 09:09 PM |
| Transformer questions | Trout | Tubes / Valves | 3 | 1st February 2005 01:19 PM |
| More transformer questions! | Edgar | Solid State | 6 | 26th October 2001 10:56 AM |
| Page generated in 0.08743 seconds (71.70% PHP - 28.30% MySQL) with 10 queries |
