Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th June 2010, 04:24 AM   #1
diblet is offline diblet  United States
Default help looking for a space saving isolation transformer for a portable tube amp
i have a tube amplified portable reel to reel which has a design that connects directly to ac which i would like to add an isolation transformer to - however the one i currently have is a tight fit.
so i was wondering if anyone might have any ideas of a smaller isolation transformer that they might recommend?
_
the unit i am adding isolation to wants 115 AC, 60VA 60C/S (according to the plate on the outside of the unit)
the isolation transformer i have on hand is 115 AC, 80VA dimensions 2.5"h x 3" x 2.75" - it is a tight fit and i would have to modify the case a bit to get it to fit (to gain about 1/4" or so on the height)
i mainly need one that is shorter than 2.5" h - i found this toroid unit, but it is 117V ...
it measures 1.52"H×3.73"O.D - so that one might fit... i'd have to build a dummy to know for sure if the diameter is okay
_
just curious if anyone has any suggestions for a space saving isolating transformer for my application...
thanks!
here is a schematic of the unit i am adding isolation to:
Old 13th June 2010, 06:08 AM   #2
My suggestion is not to isolate the motor. That should reduce the load sufficiently to use a smaller transformer. The heaters draw 150 mA and the plates maybe half that, so you have a load less than 1/4 A, and a 30 VA transformer might do it.
The next step in reducing the load would be to allow the heaters to remain on the line and just isolate the plate of the rectifier. I don't like that, as it may create excessive heater-cathode potentials that could cause hum or even tube failures.
Old 13th June 2010, 05:08 PM   #3
oh that sounds great - i was actually planning on not isolating the motor anyway (as it is a pole motor and has its own transformer already) to keep the heat down on the isolation transformer
i think there is a cheap 50VA transformer i know of that will fit nicely in the unit - i just didn't know how to determine the VA i needed other than what the case said...
thanks so much - i'll give it a shot!
isolation transformer for 50C5 amp PRNDL Tubes / Valves 18 17th June 2013 08:26 PM
NASA space-age tube for audio use makaiyumtony Tubes / Valves 14 26th December 2009 09:37 PM
Portable Tube/Hybrid Headphone Amp petesjoy Headphone Systems 1 15th November 2009 12:57 PM
isolation transformer won't supply filiments - 1968 Harmony H400A tube guitar amp tonebrulee Tubes / Valves 7 9th April 2008 05:33 PM
Using isolation transformer as a PSU transformer??? Yaho Tubes / Valves 10 27th February 2008 04:16 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
