diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   Where to buy step-down toroidal transformer with electrostatic shield? (http://www.diyaudio.com/forums/power-supplies/168309-where-buy-step-down-toroidal-transformer-electrostatic-shield.html)
Kuro 9th June 2010 09:15 AM
I'm looking for a high quality 50VA toroidal transformer with 6-0-6V output (or 2x0-6V)or 7-0-7V output (or 2x0-7V). I prefer having two primaries of 0-115V each so I can use it in parallel or in series.
Ideally, I'd prefer the transformer having an electrostatic shield b/w primary and secondary with wire from the shield for grounding. This is to avoid noise coupling from primary to secondary.
So far, I only see Nuvotem meeting most of the specs., but I don't see anyone advertising transformers with electrostatic shield.
jcx 13th June 2010 02:01 AM
shielded toroid still has large C between the windings and the shield - so you have the problem of where to gnd the shield
I'd rather have the order of magnitude less C in a split bobbin EI and forgo the shield
Kuro 15th June 2010 04:19 PM
The problem is that I've a space constraint so an EI won't fit. Plus the fact that I don't want excessive heat from an EI.
Is there a way I can measure the capacitance of a toroid?
ackcheng 15th June 2010 04:32 PM
try plitron
Copyright 1999-2017 diyAudio
