Help need with PS for Idiot Help need with PS for Idiot - diyAudio
Old 8th June 2010, 08:45 PM   #1
semi932 is offline semi932  United States
semi932's Avatar
Unhappy Help need with PS for Idiot
I'm building a phono amp and need + and - 15v sources.
I'm trying to tap into an old realistic amp SA-155.
Got two red wires from the transformer that go to posts and read 15v AC. Yellow center tap goes to switch.
When I take these out to a full wave rectifier(one unit that I know is ok). and then to smoothing caps I get 21v on the plus side and 42v on the neg. side.
I'm using jumpers to experiment and I'm pretty sure all is wired correctly. This is all using chassis ground as a reference and all grounds tied together.
Thought I had found the perfect source to build a supply using 78 and 7915.
Maybe disconnect transformer from circuit board and try again?
Confused
Old 8th June 2010, 08:59 PM   #2
wakibaki is offline wakibaki  United Kingdom
Banned
This sounds all wrong.
You should have 2 full-wave bridges if you want to develop positive and negative supplies, with the positive output from one tied to the negative output of the other and the junction of these tied to ground.
Draw a schematic of what you have, scan or photograph it in reasonable quality and post it.
w
Old 8th June 2010, 09:17 PM   #3
ChrisA is offline ChrisA  United States
A center tapped 15V transformer is simply not going to work. For the small amount of current you need Antek will sell you exactly what you need for $10.
Antek - AN-0118
The AN-0118 looks to be about right.
It looks like from your measurements the center tap was connected to something other than ground. But it does not mater if the goal is a dual +15/-15 V supply
Old 9th June 2010, 12:06 AM   #4
semi932's Avatar
Antek - AN-0118
Good link. Thanks for that helpful viewpoint.
You can tell I'm kind of a newbie so I appreciate the advice.
So a center tap won't work? I ask that for my education.
I'm posting a couple pics so you can maybe get a clearer idea what I'm saying.
And the center tap(or center wire) is connected to off/on switch board but no voltage on it.
Only one pic would upload. I even resized others but maybe this will do.
Old 9th June 2010, 02:07 AM   #5
bob91343 is offline bob91343  United States
A pair of 9V batteries would probably work for a year and save you a lot of grief. You probably don't need the full 15V.
Old 9th June 2010, 04:07 AM   #6
infinia is offline infinia  United States
infinia's Avatar
Well the center tap is the return for both your new supplies, since it's not grounded but switched that could be one of your problems here.
I would disconnect the 2 reds since they might be connected to 2 rectifiers onboard, and use centertap for all returns and measurements. Otherwise 2x15VAC s/b near perfect for +/-15 volt regulators using one full wave bridge (ie 4 rectifiers)
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 9th June 2010, 04:18 AM   #7
semi932's Avatar
Good diagnosis.
Reds are connected to on board bridge. Yellow was connected to off/on switch.
I unsoldered yellow and configured it as zero volt line and perfect. 22v+ and-22 with full wave. Should work nice for regulated 15v I hope.
Thanks again
Old 9th June 2010, 07:13 AM   #8
A center tapped transformer would work fine. But an 18V CT one will not
18 V CT means there are 18 volts across the full secondary and 9 volts from the CT to either end. An 18V CT transformer is sometimes called 9-0-9 volts and I think this way is more informative. If you could find a 36 CT or 18-0-18 you'd be able to build a +/- 15 volt split supply.
As a rules of thumb rectified DC volts are abut 1.2 times the AC volts from the transformer. It not an exact rule but provides a good start. Then figure the regulator will drop the volts at least by 2V, or 3V to be safer. Work backwards to find the transformers you need. However a CRC filter in front of the regulator can drop voltage too
Old 9th June 2010, 09:55 AM   #9
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
18V CT (9-0-9) will work with a voltage doubler or by grounding one end of the secondary winding and feding two opposite polarity half wave rectifiers with the other end.
I use to feel like the small child in The Emperor's New Clothes tale
Old 10th June 2010, 07:34 PM   #10
semi932's Avatar
Might not have been specific in my first post.
Two red wires put out 15vac each.
My apologies.
Help need with PS for IdiotHide this!Advertise here!
Couple idiot questions.... raypalmer Tubes / Valves 34 23rd April 2010 09:51 PM
Couple idiot questions.... raypalmer Tubes / Valves 1 22nd January 2010 01:38 AM
I Am An Idiot LORNECALIFORNIA Car Audio 5 18th January 2008 09:45 AM
help me im an idiot dangerous dan Multi-Way 3 18th November 2005 04:43 PM
Copyright ©1999-2017 diyAudio
