Go Back   Home > Forums > Amplifiers > Power Supplies
Old 8th June 2010, 06:09 PM   #1
Default Amp needed for speakers
Hi All,
i have four speakers the have following specs: 3W and 8ohm each.
I want to attach an amp so i can power them. i don't know what i should get and if i should connect them in parallel or in sequence. also if amp could be small it'd be great.
any help/advice is brilliant.
Old 8th June 2010, 07:02 PM   #2
ChrisA is offline ChrisA  United States
What's the application? Connect two of the speakers in series, twice to make two strings then connect the two string in parallel. The resulting network will be 8 ohms and can take 12W. Almost any amp will work fine for such a low load at 8 ohm
Old 10th June 2010, 09:08 PM   #3
firechief's Avatar
Ok Chris A is right - see this little diagram for series parallel connection,. In your case all of the speakers are 8 ohm so the total to the amp is 8 ohm
Problem with my speakers, help needed... cchean Multi-Way 2 22nd September 2009 07:22 PM
Help needed with DLS speakers duvla Car Audio 3 12th September 2007 12:26 AM
Advice about modifiying speakers needed stubs Multi-Way 7 13th September 2006 02:21 PM
Advice needed for new speakers! Timbo Multi-Way 12 2nd September 2006 09:54 AM
Amp needed for measuring speakers with laptop JohanH Multi-Way 7 24th February 2005 06:28 PM
Page generated in 0.08437 seconds (69.30% PHP - 30.70% MySQL) with 11 queries
