Wire Kit for Battery
Old 30th May 2010, 01:54 AM   #11
BubbaGump is offline BubbaGump  United States
Heres what I've got right now, and it isn't working: The positive lead is on X2, the negative on the other DC input hole.
Regulator is bypassed with a wire jumping the two outside holes together, the middle is left untouched.
Also, I removed the LED because I was unsure of polarity and simply bridged it with a wire.
Anything wrong with that? Why might it not be working?
Old 30th May 2010, 12:22 PM   #12
RJM1 is offline RJM1  United States
To make it simple just run your positive lead to the jumper that you pu across the two outer leads of the regulator and your negative lead to the middle pin of the regulator.
And take that jumper off where you removed the LED you will just draw current and shorten your battery life. A LED lights when it is forward biased (draws current) and does not light or draw current when it is in backwards unless you exceed it's break down rating.
Wire Kit for BatteryHide this!Advertise here!
Wire DC Power Jack for 9V Battery BubbaGump Power Supplies 2 28th May 2010 03:40 AM
Amp6-BASIC kit and 12v lead battery mallerfar Class D 0 25th June 2009 05:47 PM
Looking for amp kit that runs on 12V (car battery) maurycy Chip Amps 5 2nd October 2008 08:29 PM
24bit/192KHz DAC DIY KIT battery power boidos Digital Source 3 23rd June 2008 06:46 AM
Elektor Battery Preamp Kit for sale Jason Hubbard Swap Meet 0 18th June 2001 12:58 PM
