Modifying Powersupply
Old 30th May 2010, 01:37 AM   #11
KnightofAwesome is offline KnightofAwesome  Canada
KnightofAwesome's Avatar
Originally Posted by amc184 View Post
Here's the picture I meant to attach. If it's not an integrated amp, what's the +/- 36V for?
For the +36volt rail and the -36volt rail of the powersupply are for a discrete class A poweramplifyer (Blame ST). The +/-36volts is an estimate of what will happen if i drop the secondary voltage of the transformer by six volts from the original schematic (Was +/-42volts). I have no clue if this will even work. And i still need to set the values of the two resistors and capasitor in the relay circuit, which might I add, can't be done untell I know for certan what the VAC of the secondary side needs to be inorder to get the 36volts on the rails for the Blame ST.
If i drop the voltage to 24volts (from 30volts) on the primary side of transformer and stick a second 1N4007 before the rectifier(Which connects to the Voltage regulator). Then the LM7805T will only need to regulate 24volts, right? I think the Lightspeed will be pulling less then 1 amp.
I would like to create some sort of alterd schematic from the original schematic so that I can doccument the changes. Starting will removing the six 1N4007 leading to the 56volt rails.
Thanks for all your help so far!
Kurtis
Modifying PowersupplyHide this!Advertise here!
powersupply tojoko Chip Amps 10 25th February 2009 07:19 PM
powersupply not sure what to do? prorms Solid State 3 14th November 2006 02:39 AM
Powersupply Kongen Solid State 4 26th October 2003 04:19 PM
Copyright ©1999-2017 diyAudio
