How easy is it to replace a transformer in a linear power supply? - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 7th June 2010, 10:55 AM   #11
Ok so I guess its not worth the effort. I have a question though Ive seen many isolation transformers that are used stop rf noise from entering the AC wiring and most of these use toroidal transformers how do these stop rf noise from going back to the mains?
Old 7th June 2010, 11:20 AM   #12
infinia is offline infinia  United States
infinia's Avatar
The good ones only use EI types for mid band (audio) noise rejection, At RF frequencies they all use shielded cans or IEC line modules containing LC filters and common mode chokes. Any isolation XFMR using toroid's would need additional filtering to match a split bobbin with physically separated input and output windings.
Isolation only requires the pri-sec windings meet some 1500 V leakage current ie well insulated from each other. Line conditioner XFMRs need more than that. These will usually spec a capacitance and have a electrostatic shield. In order for the electrostatic shield to be effective it needs dedicated reference earth grounds.
see here
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
linear pc power supply? cowanrg Power Supplies 45 20th July 2012 03:49 PM
Power supply Linear or Switching Williams Audio Solid State 26 16th March 2009 09:03 AM
LM1875 power supply question (easy) madisonears Chip Amps 12 24th February 2008 11:41 AM
Can a variac replace the power transformer gnomus Pass Labs 9 18th December 2002 03:30 PM
Copyright 1999-2017 diyAudio
