Hi everyone, I have a 13.8V 4A linear power supply, its a samlex rps1204. I want to replace the steel plate transformer it has with a toroidal transformer.
There's no info anywhere on the transformer. The transformer has two cables for the AC input and 3 output cables that go to the small circuit board.
How easy would it be to replace it? Ive seen several 12v toroidal transformers on ebay and partsexpress would any of these be an ok drop in replacement?
I have experience working on house wiring, I know how to use a multi-meter, and I can solder. thanks
As there are three wires this is probably wired to two diodes as a Bi-Phase circuit. Measure the AC voltage of the current transformer, this will give the transformer required at a guess 15 - 0 - 15 @ 60VA. Then its a size and mounting problem.
Be careful when measuring the voltage as the case will be open and the live mains probably exposed
The question has to be asked why? This appears from the voltage to be a car battery replacement unit for driving car audio. Correct me if I'm wrong
If the PSU is working a toroid wont make any difference in my opinion.
Ok I measured the the three outputs; when I measure 1 and 2 it gives me 18.80V when I measure 2 and 3 it gives me 18.80V, and when I measure 1 and 3 it gives me 37.62V.
From what Ive been reading it seem it might offer some sonic improvement such as lower noise , I think it will also be good practice since I would like to replace the transformer on my tube dac with a toriodal one eventually.
Im not sure what its used for, I bought it for my t-amp, heres is a link of it. I can also take pics of the inside of it if needed.
Pure Sine Wave Inverters, Modified Sine Wave Inverters, Battery Chargers, Solar Panels, Solar Charge Controllers
there is some, many would say much and measured, anecdotal evidence that a square frame transformer attenuates HF artefacts more than a toroidal does.
PS.
what was the mains' voltage when you took those measurements?
What was the load when you took those measurements?
What is your normal mains voltage where you intend using this transformer?
PS.
you probably have a 120:15Vac transformer. Regulation is ~25% about typical for a small EI.The AC in my house was 120vac when I took the measurements
No load was connected to it.
120vac will be the normal mains voltage
Infinia agrees with the majority. Don't go to toroid unless you have good evidence to show why/how the toroid improves on the square frame.
There was an article I read about how toroidal transformers provide much better sound than other transformers, they said this was due to their efficiency and lower magnetic flux, I have a gauss meter which measures
ac magnetic fields at 50/60hz and indeed the the transformer emits a strong magentic field which extends about 5-6ft. Most high-end gear and pro gear use them, and many DIY'ers seem to use them for their builds
here is another article I read
Sound Lab Technology: Toroidal audio transformers for superior resolution
Samlex finally got back to me here is the info they gave me on the transformer.
Power: 200VA
Primary : 120 VAC, 60 HZ
Center tapped Secondary (No load): 37.5 V ( 18.8 V from one leg to the center tap)
Power: 200VA
SilverStrings the article you linked above is about audio output transformers it's not for power supplies with solid state regulators. You don't want tighter coupling for a PS except at 60Hz. That's why using toroid's for a PS feeds more mains HF garbage through past the regulator. FWIW Standard split bobbin IE core XFMRs are excellent line conditioners with a few more filter components.
Ok so I guess its not worth the effort. I have a question though Ive seen many isolation transformers that are used stop rf noise from entering the AC wiring and most of these use toroidal transformers how do these stop rf noise from going back to the mains?
The good ones only use EI types for mid band (audio) noise rejection, At RF frequencies they all use shielded cans or IEC line modules containing LC filters and common mode chokes. Any isolation XFMR using toroid's would need additional filtering to match a split bobbin with physically separated input and output windings.
Isolation only requires the pri-sec windings meet some 1500 V leakage current ie well insulated from each other. Line conditioner XFMRs need more than that. These will usually spec a capacitance and have a electrostatic shield. In order for the electrostatic shield to be effective it needs dedicated reference earth grounds.
see here
- Power Supplies
- How easy is it to replace a transformer in a linear power supply?
