Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th May 2010, 08:43 PM   #1
Default Synchronous Rectification
Hello, this method from synchronous rectification is good ?
Old 26th May 2010, 01:07 AM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
No, this is better.
http://myweb.msoe.edu/williamstm/Ima...409_Schem2.png
http://myweb.msoe.edu/williamstm/Ima...409_Schem3.png
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 26th May 2010, 01:12 PM   #3
Hello and thank you for the schematics.
I've looked at them and from what I can tell the differences are the mosfter polarity and the
direct command of the mosfets from the totempole, with a ground common to the PWM integrated circuit.
The reversed polarity of the mosfets works in my case but I can't use a common ground, that's why
I went with a GDT command.
To me they look mostly identical, please correct me if I'm wrong.
Old 27th May 2010, 04:49 AM   #4
Sch3mat1c's Avatar
The two sets of rectifier transistors have to be on simultaneously, while the inverter transistors are off. A GDT cannot provide this action.
Tim
Old 27th May 2010, 05:27 AM   #5
I'm confused, do you mean whit GDT i have no power to turn off large input capacitance of rectifier mosfet? I can add an pnp transistor to turn off rectifier mosfet.
What is your opinion?
Old 28th May 2010, 09:50 PM   #6
Sch3mat1c's Avatar
No.
The required waveform is fundamentally different.
This is the inverter waveform (top), and drain waveform at the rectifier, with gate drive disconnected.
Both rectifier transistors must be turned on during dead time (shown here at +12V).
Tim
Old 29th May 2010, 05:47 AM   #7
orfeus is offline orfeus  Greece
I suggest you the LTC3722. It's expensive but it gives much more design flexibility. It can be cooperate with a second stage controller to make various modifications. The problem is that you will have to deal with full bridge rectification. Download and the software. It will help you.
Using Self-Driven Synchronous Rectification in SMPS albert_emule Power Supplies 0 26th July 2009 12:02 AM
Duelund synchronous crossover angel Multi-Way 7 8th November 2008 12:02 PM
synchronous buck converter SwedishWings Power Supplies 5 24th April 2008 07:00 PM
Synchronous Reclocker. Feedback please riotubes Digital Source 10 15th March 2007 02:20 PM
How to implement synchronous clocking regal Digital Source 2 20th August 2006 02:57 AM
Page generated in 0.09661 seconds (71.79% PHP - 28.21% MySQL) with 11 queries
