Power supply problem
Old 24th May 2010, 08:12 PM   #1
vidc is offline vidc  Croatia
Default Power supply problem
hi,
i made dual power supply with two separated tranfsormers. here is schematic:
problem is when it's not loaded,i measure around +26 Volts V+ to GND, and around -26.xx Volts ,V- to GND.but problem is when i connect amp to it,the negative rail drops to zero,positive remains ok (cca 26 Volts).Transformer for the negative rail have enough power i presume...i got it out of my old 30W hi-fi...,here i need about the same power for one power supply rail
what could be the problem here?why should power supply voltage drop after connecting it to load??
thank you
sorry for bad picture quality,it was edited in mspaint
Old 24th May 2010, 10:10 PM   #2
bob91343 is offline bob91343  United States
Maybe a short, or poor connection. Measure at the capacitors. Measure to see if the load is shorted.
Old 24th May 2010, 10:24 PM   #3
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
The bridge rectifier on the lower winding is the wrong way round.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 25th May 2010, 12:37 AM   #4
well,i found this schematic on internet because it was similar to mine and modified a little.i think that the bridge orientation is ok,i presume it should be ok because i actually get what i was expecting when the load is not connected to it...
@bob: i measured it right on caps,same thing...tried it on two different amp PCB-s,same problem...i doubt that load is shorted
now,i'm thinking it could be the capacitor...but i don't have enough experience to be sure.
is it possible that cap broke in a way that it is working "properly" when there isn't load connected and doesn't do it's job when actually some current is needed?
Old 25th May 2010, 05:45 AM   #5
The diagram is correct.
I suspect a high resistance somewhere, like a bad solder joint or similar. Load the negative section with a resistor to make sure the problem isn't in the load itself. In fact, measure the current to see what's coming out.
I had a similar problem a few years ago where everything looked perfect but no output under load. It was a bad solder joint, even though it looked good. Must have gotten a bubble or something in the solder and the connection wasn't being made. Yet there was enough leakage that with no load all looked okay.
Old 25th May 2010, 10:26 AM   #6
ok,i will try that today.
thank you!!
Old 25th May 2010, 11:31 AM   #7
power it up through a mains bulb tester.
Check each half completely independently.
Then create the centre tap at the output.
Check again. You should get 52Vdc across the whole doubled up PSU and +-26Vdc when using that centre tap as the ground (black probe).
regards Andrew T.
Old 26th May 2010, 04:51 PM   #8
problem solved.
the load was shorted in the end.the problem was that the loads were TDA 2050 and LM 3886 chipamps...and i put them on heat sink which was screwed on chasis.chasis is grounded,and tab of both chips is on V- potential,so it was shorted through the heat sink.i found that after puting 2W reistance and everything was ok,then checked datasheets of both chips and found out that i was complete idiot
thanks anyway,i appreciate your help!!
Old 26th May 2010, 05:11 PM   #9
and the tester would have lit up to tell you something was trying to draw too much current.
It would also allow the PSU to power up to full voltage and when you added the amp/s it would have powered up at very low voltage and give you time to measure what was wrong.
regards Andrew T.
Old 26th May 2010, 06:29 PM   #10
i guess it would,but its little complicated.i'm living in a dormitory so i'm little short with equipment...but in the future i'm planning to get bulb tester (and other equipment) to make my life easier
thanks
Power supply problemHide this!Advertise here!
Power supply problem Niila Tubes / Valves 6 12th April 2008 02:39 AM
Power Supply problem Landoctor Chip Amps 3 8th September 2007 08:50 PM
Power supply problem krzanik Tubes / Valves 19 1st May 2007 04:56 PM
Power supply problem??? wintermute Solid State 22 12th October 2003 08:20 AM
Power supply problem (or something) ir Chip Amps 4 23rd August 2003 09:44 AM
Copyright ©1999-2017 diyAudio
