Go Back   Home > Forums > Amplifiers > Power Supplies
Old 22nd May 2010, 04:45 PM   #1
semi932 is offline semi932  United States
semi932's Avatar
Default Newbie question about transformer?
Did some searching and can't seem to find the answer.
I'm posting a couple pics of transformers and how they are wired in a chip amp.
The black and red the way they are wired put out approx. 23VAC from each transformer.
If I split the black and red to use one transformer for each bridge, what will the output of each wire be?
Will it stay the same or be halved?
Info on the transformers is pretty vague. Just 300VA. 120v, but no output numbers.
Need basic education.
Old 22nd May 2010, 04:52 PM   #2
I'm pretty sure you'll get 11.5VAC each, right now your probly getting +- 11.5, that's the 23VAC. The best way to use those transformers is in series.
Old 24th May 2010, 06:31 PM   #3
semi932's Avatar
As it turns out, we're both off. After doing some more research on this site,
Building a Gainclone chip amp power supply.
I am finally getting to understand how transformers work.
I didn't have a real clue.
Really educational site by the way and I know many members are very familiar with it and some helped write it.
Thanks.
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Newbie Transformer question sachi Chip Amps 5 11th July 2005 06:59 AM
Newbie transformer question Lugoman Chip Amps 1 9th March 2004 10:20 PM
Newbie transformer question Wingfeather Parts 3 28th April 2003 10:10 AM
newbie post, but hopefully not a newbie question wiredcur Solid State 3 24th August 2002 10:49 PM
Page generated in 0.08626 seconds (71.17% PHP - 28.83% MySQL) with 11 queries
