+/- 12v dc PSU Required
Old 17th May 2010, 11:55 AM   #1
ChrisR1983 is offline ChrisR1983  United Kingdom
Default +/- 12v dc PSU Required
Gents
Anyone know where I can get a kit for a PSU that does:
Standard UK 230v AC to +12v DC AND -12v DC? Nothing too complicated. Or preferably something ready made.
This is for a wolfson DAC evaluation board.
Chris
Chris R
Old 18th May 2010, 07:15 AM   #2
Mooly's Avatar
Well I thought that would be easy... and I haven't found one kit for what you want.
Why not make your own... dead easy, very low cost.
All you need is a suitable transformer, one bridge rectifier, two 78/79 series IC's and a handful of caps (four would do it, for the economy job )
Old 18th May 2010, 07:37 AM   #3
col is offline col  Australia
col's Avatar
or if you want something with a PCB, could get this and a couple of 12v regs:
Universal +/-15V Power Supply - Jaycar Electronics
col.
http://www.minirig.org.au
Old 18th May 2010, 07:55 AM   #4
The idea of making it doesn't frighten me away but I'm not great when it comes to understanding schematics. I'm a bit rubbish. Also, a PCB would help a lot.
Any clear instructions anywhere for a novice? (sorry - I'm a speaker builder - not great with electronics - eeek!)
Chris R
Old 18th May 2010, 08:06 AM   #5
col's Avatar
The Jaycar kit comes with PCB and assembly instructions, it has 15v regs 7915/7815. If you get a 7912/7812 pair you can just use them instead. Very easy.
col.
Old 18th May 2010, 08:17 AM   #6
Yes - the jaycar one does look like it fits the bill actually. I need a 12v transformer for this - do I need centre tapped or dual secondaries? I have one of these: AC 230 V Toroidal Mains Transformers : Mains Transformers : Maplin - if I can't use that, what can I use?
Thanks all for your help so far
Cheers
Chris
Chris R
Old 18th May 2010, 09:39 AM   #7
col's Avatar
yeah the N91AZ will do the trick.
col.
Old 18th May 2010, 09:40 AM   #8
Thanks for your help :-)
Chris R
Old 18th May 2010, 09:45 AM   #9
col's Avatar
when you order the 7912/7812 regulators make sure you get them in a TO-220 package.
col.
Old 18th May 2010, 10:41 AM   #10
Mooly's Avatar
Chris... useful as Maplin are they are shall we say somewhat overpriced.
Have you any idea how much current the DAC needs... it will be well within the 78 regs capability but if it's much over a 100 ma or so you might need heatsinks on the regs.
A 12-0-12 tranny gives 17-0-17 volts DC after rectifying so that's 5 volts the reg has to drop. At 100ma thats 0.5 watts, anything higher than say 1 watt and a heatsink is needed.
Just something to watch... if you can hold a finger on the reg for 10 seconds and it doesn't burn then it's OK.
Have a look at,
Your Search Results | CPC
They do all the other components too.
+/- 12v dc PSU RequiredHide this!Advertise here!
to convert a 12v dc car adapter to support 19 volts dc shadiedog87 Power Supplies 6 31st October 2007 07:27 PM
Easy PSU question - help me make this 12v DC power supply better. owdi Power Supplies 8 2nd May 2007 04:42 PM
PSU for 12V DC heaters cbutterworth Tubes / Valves 15 9th March 2007 06:25 AM
12v dc to dc 100w psu razordave123 Power Supplies 13 7th February 2006 04:29 PM
12V-220V(ac) to 12V-50V(dc) raszvan Car Audio 0 16th June 2005 08:28 AM
