Go Back   Home > Forums > Amplifiers > Power Supplies
Old 16th May 2010, 02:02 PM   #1
Default 15v Halogen switched mode power supply
This is my first post so excuse if I go on or am unclear.
Basically I have a power supply board inside a unit that drives a 150w 15v halogen lamp. Now the transistors have had to be replaced as they overheated. What please could cause this, could it be the toroidal coil thats pulling too much current, and if so what replacement would anyone recommend.
This smps employs the BUL59 transistors apparently they are arranged in a "push-pull" configuration, but it did get very hot.
Look forward to your replies.
Colin.
PS. This happens to be a disco lighting fixture, I know this is diyaudio but I am a bit of a loss. Help!!!
Old 17th May 2010, 11:13 AM   #2
Mooly is online now Mooly  United Kingdom
Mooly's Avatar
Well I can only offer at best general comments... I have never worked on anything like you describe, or know much about it, although I am very familiar with working on SMPS in commercial equipment etc... but never lamp dimmers However it's always good to expand your knowledge.
First a link to something that may be like you describe,
http://www.datasheetcatalog.org/data...cs/mXyzxvz.pdf
Transistors used as switches (The BUL59) are used such that they are either fully on, so there is little voltage across them but large current flowing, or fully off, high voltage across them but no current flowing. Used like this they run "cold".
Problems... if they are hot the usual cause is that the switching isn't correct, if they are ina a push/pull arrangement there may be "overlap" in the conduction where both devices are on for a short time resulting in the overheating, or the drive waveform may be wrong.
If the unit has a control circuit using an IC etc, any electroylitic capacitors are always favourite failure items, they are highly stressed in these types of application. Cap failure is the cause of 95% of PSU problems in SMPS.
Other than that it's hard to say without seeing a full circuit and testing and measuring... they are so many possibilites.
A simulation free zone. Design it, build it, test it.
Old 18th May 2010, 08:49 AM   #3
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
This is probably a self oscillating circuit. Transistor selection is critical, the wrong type of transistors won't switch fast enough (or won't have a low enough saturation voltage) and will get really hot and fail. Be aware of fake transistors.
Open capacitors or resistors, or shorted diodes (or wrong type), may give the same result.
Were the old transistors really damaged? Replacing stuff that is not damaged is not a good idea in switching power supplies, unless you know that the new parts are exactly the same as the old ones.
Note that transformers are very unlikely to fail.
I use to feel like the small child in The Emperor's New Clothes tale
Circuit Sanity Check: +15V, -15V, +9V Power Supply miallen Power Supplies 4 18th July 2009 07:18 PM
PFC Switched-Mode Power Supply N-Channel Power Supplies 57 13th June 2005 07:56 PM
Switched mode power supply MMicke Car Audio 3 19th February 2005 10:42 AM
filtering switched mode PSU for SI 5066 amp supply jives11 Parts 0 24th January 2005 09:19 PM
Switched Mode vs Linear Power Supply royalmp2001 Solid State 4 12th July 2002 08:04 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
