diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   2kw inverter charger (http://www.diyaudio.com/forums/power-supplies/166650-2kw-inverter-charger.html)
ptinarwo 10th May 2010 01:19 PM
i am repairing an inverter charger that keeps blowing IRF740 transistors, three of the ics are erased please help identify.
Cristi 10th May 2010 03:26 PM
why do i have a hunch that if there are erased ic's they can be either SG3525, or TL494 as smps controllers, MC4013 for the high voltage inverter stage, and some LM339, LM324 as OP-amp, comparators for various functions.
do you have some pictures ? it might be helpful to identify them easily. in the meantime just take the datasheet of the above ic's and try to indentify them looking after the GND, Vcc pins and then inputs, outputs, etc.
Copyright 1999-2017 diyAudio
