Go Back   Home > Forums > Amplifiers > Power Supplies
Old 8th May 2010, 04:46 AM   #1
thadman is offline thadman  United States
Default High Speed PCB Layout
Could anyone recommend any resources for researching high speed PCB layout?
I'm aware that parasitic inductance / capacitance as a result of the PCB layout (ex. traces) has a significant effect on the stability of the control loop.
What grounding techniques are recommended for high speed circuits?
I believe the TI TLV3502 comparator can switch in 4.5ns and transresistance amplifiers are able to operate in excess of 100Mhz. However, I believe the limiting factor will be the PCB layout. What is a realistic high speed limit for discrete analog circuits?
Thanks,
Thadman
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them."
Old 8th May 2010, 07:58 AM   #2
Account Disabled
Post Layout
Hello
Use split planes for power, ground, and signal ground, and if possible use multi layer pcb.
Old 8th May 2010, 11:39 AM   #3
stormsonic's Avatar
check this link Signal Consulting, Inc. - High Speed Digital Design and Signal Integrity Solutions
Eagle vs. Sprint-Layout for PCB design/layout hollowman Parts 9 9th July 2011 04:34 AM
High speed comparator bigbulb Class D 25 8th July 2008 09:44 PM
high speed CDP fscarpa58 Digital Source 7 11th May 2005 08:32 AM
high speed optocoupler djdamix Class D 5 21st April 2005 02:54 PM
High speed amplifier reinhard Pass Labs 13 4th June 2002 02:43 PM
Page generated in 0.07293 seconds (64.37% PHP - 35.63% MySQL) with 10 queries
