I have almost completed Legend Stage Mk2 I just need the power supply to power it up So i need wind my transformer ............ So here r the data for the transformer winding as i am not very sure that my calculations r very correct plz help me out with this:-
CORE TYPE = EI VA=1300 WIDTH OF CENTRAL LIMB=2 INCH TURN PER VOLT = 1 PRIMARY CURRENT = 6.64A PRIMARY CONDUCTOR DIAMETER =1.9mm(15 SWG) NO OF PRIMARY WINDING = 230 SECONDARY WINDING CURRENT = 10A SECONDARY CONDUCTOR DIAMETER = 2.488 (13 SWG) NUMBER OF SECONDARY WINDING = 68 + 68 WINDOW AREA = 1699mm^2 PLZ HELP ME WITH THE CALCULATIONS CORRECT ME IF I AM WRONG REGARDS SEKHAR |
#2 |
sekhar,
are you using the standard EI-200?
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#3 |
IN my country the EI cores have numbers such as 6,7,8 i have no idea about EI-200 the spec of the EI core i intend to uses is
core no 43 ![]() the core no 43 as shown has a window area of 1905mm^2 but the required window area is 2043mm^2 by any means is it possible to build the transformer in the given core?????????????????????? regards sekhar Last edited by sekhar; 9th May 2010 at 07:51 AM. |
#4 | |
window area=2043mm^2 regards sekhar |
#5 |
ok, that is EI-200, i can not shake off the imperial units in my head.....i do however use both at the same time...
so you have a window of 1 inch x 3 inches, or 25mm x 75 mm. 80% of available window is for the copper wires, 50% of which is for primary coil and 50% for secondary coils. these are your guides, the actual number of primary turns will depend on these guidelines.....
#6 |
as u see tony the given core has a window area of 1875mm^ but the needed area is 2043mm^2 so how do i cope up with that is there any other way without using a bigger core..................??????????????????
regards sekhar |
#7 |
hey cant an body help me with the design of this transformer i am newbie ,,,,,,,,,, I have done most of the calculations kindly help me in selecting the right core .................
regards sekhar |
#8 |
are you using grain oriented or non-oriented steel? i ask becasue there is significant difference between two types...
#9 |
ok, you need 4inch stack of 2 inch center leg core.
#15 primary will have 44turns per layer so 5 layers are needed and the copper build-up is 7.25 mm... #13 secondary will have about 35 turns per layer, 4 layers are needed and coil build-up will be 7.6 mm.. total build-up is 14.85, so that you will still have 10mm for bobbin and insulations to play with... i strongly reccomend you wind your secondary biffiliar so as to have exactly the same secondary voltage....
#10 | |
tony ur and my calculation does nt match No of turns per layers in primary=3*2.54/1.9=40 no of layers required =230/40=5.75 ~ 6 Coil build up = 6 x 1.9 = 11.4mm No of turns per layer secondary = 30 NO of layers required = 4.5 ~ 5 Coil build up = 5 x 2.488 = 12.44 total coil build up in primary & secondary = 12.44 + 11.4 = 23.8 That quite a narrow margin I think........................ And how did reach the figures that u mentioned above cause according to ur calculation #15 primary will have 44turns per layer so 5 layers are needed and the copper build-up is 7.25 mm...(5 x 1.9 = 9.5mm)& how r u placing 44 turn in a 3inch bobin it could accomodate max 40 turn #13 secondary will have about 35 turns per layer, 4 layers are needed and coil build-up will be 7.6 mm..(2.488 x 4= 9.952) total build up =9.952+9.5= 19.452mm regards sekhar |
| LEGEND sTAGE MK2 IN MAKING............ | sekhar | Solid State | 88 | 8th May 2012 04:55 PM |
| legend stage master mk2 | black | Solid State | 1 | 11th April 2010 12:52 AM |
| Marantz CD 65 MK2 schematics PLEASE ANYONE??? | zygibajt | Digital Source | 2 | 22nd November 2007 01:17 PM |
| Antiphase wired second transformer in a 65-0-65 PSU to reduce ripple | the toasted | Solid State | 6 | 18th February 2003 02:13 PM |
| Antiphase wired second transformer in a 65-0-65 PSU to reduce ripple | the toasted | Parts | 1 | 16th February 2003 06:06 PM |
| Page generated in 0.14826 seconds (75.95% PHP - 24.05% MySQL) with 11 queries |
