hi just wondering what would the easiest way to make a 45 V +/- and a 60 +/- volt power supply for my amp i ordered on the net
#2 |
You haven't said what current.
A centre tapped transformer of 28-0-28 vac would give -/+40 volts DC, and a little higher off load. Is the -/+60 for driver stages/front end. If so and it's low current a voltage doubler and regulator would mean you could derive it from the 28-0-28. If it's the other way round, you need a 40-0-40 vac transformer to give -/+60 volts approximately and use a regulator to derive your 45 volt rails. Or use two transformers.... messy
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 |
Or get a (custom) transformer with dual centre-tapped secondaries. one 28-0-28 and one 40-0-40
#4 |
hi i need at least 6 amps for the 40+/- supply and a low current for the 60+/- supply
#5 | |
Next easiest is two off the shelf transformers. Folowed by paying for a custom wound job.
| High Power Transformer/Power supply PCB for Sale. | Count Tubeula | Parts | 1 | 15th March 2010 06:30 PM |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| is there a circuit for a power supply to power the differant add on clocks | frank2395 | Digital Source | 1 | 30th June 2005 09:33 AM |
| How do I diy Hi-End filter power supply and power cord? | bmpa | Parts | 6 | 24th April 2004 12:12 AM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
| Page generated in 0.09085 seconds (71.29% PHP - 28.71% MySQL) with 10 queries |
