Hi all,
I have on of those power supply, and I want to use it for powering a small amp and fm radio. The rated output is 12V DC 1.3A. The power supply is suitable for the amp, but probably not for the radio, as this circuit is designed for a 9V battery. My need is to drop the voltage to 9V and also to drop the current because the radio only draws 8 mA, and feeding the circuit with a 1.3A would probably damage it. What is the best way to have 9V 8mA from my power supply? Thanks, Ralf |
#2 |
Pretty simple circuit
![]() Something like this: Portable CD Player Adapter For Car Don't worry about dropping the current...the load will draw the current it needs.
Jim J. |
#3 |
I also was thinking of a L7809, but why on the circuit posted there are 4 polarized caps while on the datasheet there are only 2 non polarized caps?
Ralf |
#4 |
I think it is possible even to trim this psu to deliver 9V without any external components...
In the photos in ebay I see the trimpot inside. Very possible, that by rotating of this thing you will get the desired voltage
#5 |
Probably I wasn't clear. I would like to use one supply for both the amp and the radio, and the voltage is right for the amp. I was thinking to drop the voltage only for the radio circuit.
#6 | |
![]() Also, you can simply connect a 3.3V Zener Diode between 12V power supply and your radio, to get approx 9V This will be about 8.7V, but this should be ok...
#7 |
you can run the little power amp directly after the rectifier of the 12Vac 1.3Aac supply.
The DC voltage after rectification and smoothing will be about 16Vdc to 18Vdc. If you really meant 12Vdc then run the amp direct off that supply. From the same supply attach a lm7809 to give your 9V for the radio receiver. Download the datasheet for the lm7809 and follow the advice accurately.
regards Andrew T. |
#8 |
Mmm, never used a zener, how do I connect it?
Will this one be good (zener from rs-components)? Anyway, it will cost me less to use a L7809, if I only need the 2 non polarized caps depicted in the datasheet (0.1 and 0.33 uF), because I already have them. Regarding the current drop, anybody knows for sure that my supply won't do any harm to the radio circuit based on a TDA7000, that needs only 8mA? Thanks, Ralf |
#9 |
Glowbug is telling you the truth.
regards Andrew T. |
#10 |
The Zener solution is the cheapest.
You need a 180r to drop voltage from ~12V to ~9V. A 9V 400mW or 500mW Zener. A capacitor across the Zener. Anything from 100uF 16V electrolytic upwards.
regards Andrew T. |
| VOLTAGE DOUBLER : drop in current? | Ziggy | Tubes / Valves | 25 | 15th February 2009 01:54 AM |
| using voltage drop to calculate current | cbutterworth | Power Supplies | 2 | 3rd September 2007 01:21 AM |
| rectifier voltage drop | dsavitsk | Tubes / Valves | 8 | 10th November 2006 05:52 AM |
| voltage drop across a CCS... | pedroskova | Tubes / Valves | 4 | 8th August 2005 07:11 PM |
| voltage drop | ThSpeakerDude88 | Chip Amps | 30 | 19th July 2005 09:00 PM |
| Page generated in 0.10779 seconds (79.92% PHP - 20.08% MySQL) with 11 queries |
