Could I make my supply for a 40W stereo powr amp running in class A like this drawing, with a "floating ground".
#2 |
In theory yes... in practice it's perhaps not the best approach. If the amp has any points internally that connect to "ground" where a DC current flows or is sourced, then this will unbalance the "ground" with respect to the other rails.
Ultimately the "ground" is your chosen reference and an absolute, but it's what it does with the repect to the other rails that might be an issue ![]() You could... use an NPN/PNP pair to make a sort of active ground, still with the large caps. What's the amp anyway ?
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 |
500VA and 40+40W of ClassA does not sound quite right. I think your 500VA will be run right at it's limit delivering this power.
Each channel will need ~ 1.6A of bias to give 40W of ClassA into 8r0. Total bias for two channels is 3.2A continuous from the PSU.
regards Andrew T. |
#4 |
Yes it works.
I used it for an F5. The problem is , fo a class A amp, the total capacitor is divided by two. So tou have to add another big one across the vhole voltage. |
#5 |
#6 |
#7 |
Thank you... not familiar with it.
#8 |
#9 |
In the Quad 606, they use ztx652/ztx752
I used bd139/140, no heatsinks. |
#10 |
Ok, thanks.
IŽll try to make a schematic so maybe you guys can look through it. |
| ISO Chip Amp to Use 28v-0-28v, 2A Toroid | DreadPirate | Chip Amps | 1 | 14th November 2007 02:01 PM |
| 12v Medical Grade Switching Supply 3.3A | habsrock93 | Swap Meet | 2 | 27th April 2007 01:43 PM |
| if a power supply load is pulling 3A, does it means... | jarthel | Parts | 8 | 24th April 2007 12:58 PM |
| regulated supply +- 28V -20A | sss | Power Supplies | 8 | 14th June 2005 07:30 AM |
| Page generated in 0.11105 seconds (79.27% PHP - 20.73% MySQL) with 11 queries |
