Hi, first post, jumping right in with a question, hope that's okay!
On another forum, I have been trying to plan out a chip amp build with an STK 463 stereo amp chip, which would be pretty similar to a gainclone. Here is the current question. In the suggested power supply from the datasheet (see below), there are two 500ohm bleeder resistors. Wondering if anyone could help me understand why 500ohms was chosen, and how I should adjust if using an additional pair of 4700uf caps?
#2 |
Anybody? I guess I should have mentioned that the transformer here is +-23.25vac
#3 |
For this low freq PSU application biggest capasitor is the best. I think bleeder resistor just for discharge the capasitor after it turned off or just for idle load.
#4 |
Okay, but doesn't 500 Ohm seem on the verge of being too small? Seems like these are usually more like 1.5kOhm-5.5kOhm.
#5 |
Let me simply the question: did the mfg. select a minimal resistance for a particular reason? Or, would any safe ohm/wattage rating be just as good?
| Regulated PS for Chip amp | jomesh | Chip Amps | 6 | 17th January 2010 08:50 PM |
| Guitarist goes stereo! Chip advice needed | jwdwarren2006 | Chip Amps | 10 | 8th June 2008 04:27 PM |
| stk 463 | nbcd | Chip Amps | 3 | 3rd November 2004 12:50 PM |
| Help needed with old Sanyo STK chip amp please | georgehifi | Chip Amps | 3 | 3rd September 2004 09:14 AM |
| Bridging stk 4192 II chip | rs1026 | Chip Amps | 0 | 30th August 2004 01:41 PM |
| Page generated in 0.08496 seconds (71.94% PHP - 28.06% MySQL) with 11 queries |
