I made a previous thread where I got alot of generious help in regards to making an IC/transistorised AC generator, but I think for my mag-amp project at tube type powersupply would MUCH more simple and apropriate. I copied this basic schematic from an article which detailed mag-amp theory and practicle applications of such technology.
Imageshack - powersupplys.jpg It is the ideal powersupply for it, because it is designed for it. However, I don't know what kind of tube, inductor, ETC to use because there is no parts list. For my mag-amp supply I would like to eliminate the tube alltogether from the schematic and replace it with a rectifier, but it has a center tapped transformer and coil connected to the pentode type tube that I am not familier with. Can I assume that the tube heater element is running off of 110v mains? Then what are the grids attached to, what is that coil sitting nect to the tube for? And why is the transformer the the right of it wired like that!? I'll go with the tube design if I have to though. Once this HF supply is done, all the rest will fall into place. |
#2 |
That looks like a very weird (but not wonderful) oscillator. It would be better to run it off DC rather than AC. I think the tube is a double triode, with the common cathode in the center. The coil on the left should probably be coupled to the transformer on the right, unless it's relying on plate-grid capacitance for feedback.
![]() Anyway, to build something you need a circuit with parts values, and to generate the high frequency AC electronically, you need an oscillator with some kind of active device e.g. transistor / tube / mosfet. The other option is to go for a mechanical solution e.g. a motor-generator or something involving motor-driven rotating switch contacts. I suspect that folks who understand SMPS could find a neat way to extract the required HF power from a butchered computer PSU. btw, I'd recommend running the amp at a much higher frequency than 35khz to ease the filtering. The POC magamp at sparkbangbuzz is deceptively simple. What's not obvious is that the output is full-wave rectified 35khz AC, so the speaker's being fed more DC and more 70khz than audio. You can probably get rid of the high frequency ripple with filters but sorting out the DC will require some major re-design. |
#3 | |
#4 |
Any more ideas please folks!? Non transistor, non IC, low voltage HF AC generator @ 50 khz output.
| 35khz High Frequency AC | CivicProtection | Power Supplies | 42 | 14th June 2010 09:07 AM |
| Power supply:Universal AC input/ Full range,High Efficiency, and High reliability | hang | Vendor's Bazaar | 12 | 24th July 2009 03:46 AM |
| Annoying high frequency ringing from my 832 tube amp | kuroguy | Tubes / Valves | 13 | 7th March 2009 12:04 AM |
| high frequency high voltage power supply... | moray james | Planars & Exotics | 6 | 23rd July 2008 07:57 PM |
| Page generated in 0.09188 seconds (73.72% PHP - 26.28% MySQL) with 10 queries |
