Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th April 2010, 01:34 PM   #1
pooge is offline pooge  United States
Default Compensating for PS parasitic capacitance
It is known to select the orientation of supply lines to the primary of a power supply transformer to minimize the parasitic capacitance to ground, and thereby the ground current.
While this is all well and good, it doesn't eliminate it. Why not ADD capacitance to ground of the appropriate value to balance out the parasitic capacitances, and reduce the ground current due to this effect to zero?
Old 29th April 2010, 02:26 PM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Maybe if it's push-pull. And the harmonics are in phase. Which, unless you wound your primary out of coax, they almost certainly are not.
These things are hard to predict, so outright shielding is more effective. Most of the time, bigger capacitors (1-4.7nF) are added between grounds to shunt the noise, hoping that brute force overcomes. It passes tests, so I guess it works.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
PS Pin Capacitance LM3886 Puffin Chip Amps 9 4th March 2008 01:29 PM
PS Capacitance Puffin Chip Amps 8 3rd March 2008 10:17 AM
PS Capacitance of Aleph X lscangus Pass Labs 7 5th February 2006 02:37 PM
Compensating for Room Boundaries weinstro Multi-Way 6 2nd September 2003 03:33 PM
Disadvantages of compensating magnet? Cradle22 Multi-Way 5 18th June 2003 09:41 PM
Page generated in 0.10989 seconds (70.58% PHP - 29.42% MySQL) with 10 queries
