Go Back   Home > Forums > Amplifiers > Power Supplies
Old 28th April 2010, 09:01 PM   #1
Pwent is offline Pwent  Sweden
Default On soft start circuits and safety
Hello all
Im currently planning my first "real" amplifier project, only previous experience was a head phone amplifier. The amplifier will use a 500 or 625VA toroid, and as I understand it, it is in need of some kind of soft start circuitry to control the inrush current.
I plan to implement this through a relay controlled by a micro-controller. The same mcu will also operate the speaker muting relays and the two relays needed for stand by operation (so it can be turned on from a future pre amplifier). The relays and the mcu will be fed from a second transformer of suitable size, ~30VA 0-15.
The question is what to use to limit the current. A resistor will have to withstand some serious power, albeit for a very short time. A thermistor perhaps? I understand those are used sometimes for soft starting. While in "soft start mode" the main fuse are not likely to blow since the current is limited anyways, so it is a good idea to keep the soft start delay as short as possible? I have seen suggested (at ESP for instance) that 100ms is suitable. Commercial soft start modules seem to use ~3 seconds however. What are the ideas behind these different choices of delay length?
Any input is most welcome.
Cheers!
Old 28th April 2010, 09:24 PM   #2
Pano is offline Pano  United States
Pano's Avatar
Thermistors work for me. 3 seconds in not a bad delay for everything to stabilize.
Take the Speaker Voltage Test!
Old 28th April 2010, 10:13 PM   #3
Thanks for your prompt reply panomaniac!
Yes, three seconds should be great for stabilization. However, what can happen during those three seconds when the amplifier is essentially "unfused"? Perhaps I'm worrying to much over a non issue?
Old 28th April 2010, 10:31 PM   #4
In my F5 I've put the following soft start with thermistors and relays:
softstart circuit
The DC protection is based on upc1237: basic circuit like in the datasheet, DC protection, time delay at power on and AC level detection.
Danny
Old 28th April 2010, 10:38 PM   #5
Thanks a lot danny_66, I'll get to brooding over that right away. =)
Old 29th April 2010, 12:49 PM   #6
jrenkin is online now jrenkin  United States
Somewhere I bought some ready made softstart modules for around 15-20 bucks. I will try to find out where tonight and post it. Gotta go to work...
Old 29th April 2010, 01:05 PM   #7
Pano's Avatar
Yes, you are worrying over a non-issue. The amp is just as protected by a fuse during soft start as any other time.
Old 29th April 2010, 01:34 PM   #8
star882 is offline star882  United States
star882's Avatar
Calculate the RC time constant of your circuit, then let 5 of those constants pass before finishing the precharge.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 29th April 2010, 03:23 PM   #9
panomaniac:
Yes, true enough. But what I was thinking is that if there is a fault in the amp and something short circuits, then the fuse will not blow while the current will be limited by the soft start circuitry. Hence the amplifier will be "unfused" while the soft start operates?
star882:
The RC time constant for the filter caps in the power supply, right?
Thanks again for input!
Old 29th April 2010, 04:22 PM   #10
5th element's Avatar
The inrush you want to reduce is produced by two things.
1) The formation of the magnetic field within the transformer.
2) Charging the reservoir capacitors.
The huge inrush current created by these is only present for a very short amount of time and hence only needs limiting for fractions of a second.
Rod Elliot has two sections, one dedicated to soft start circuits and one dedicated to protection circuits that control a relay on the amplifiers output.
Here is the first. I have built something similar to the last design on that page. The opamp acts as a comparator and changes state when the voltage between R1 and C2 exceeds that present on the non inverting input.
My version is set to around 1/2 a second and it works great. To be on the safe side I used a 50 watt resistor.
If you're constructing a class A/B amplifier where the quiescent conditions require a typically small amount of standing current, then you could quite easily increase the delay to a longer time period. However if it's a class A amp, where the quiescent current is very high, then increasing the time delay will really cause the inrush limiting resistor to get hot quickly.
The other page is here. I have also built this minus the, Loss of AC Detector. It also works very well.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Soft Start Necessary? dtaylo3 Class D 2 26th December 2008 09:05 AM
B+ soft start Gluca Tubes / Valves 2 3rd September 2007 01:04 PM
Need a soft start? maxpou Solid State 19 18th April 2007 09:23 PM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
Page generated in 0.11369 seconds (83.07% PHP - 16.93% MySQL) with 10 queries
