Go Back   Home > Forums > Amplifiers > Power Supplies
Old 28th April 2010, 04:34 PM   #1
InlineTwin's Avatar
Default 230v 800va toroid on 115vac
I have a 230V single primary toroid transformer with 50-0-50 output. I would like 25-0-25 output and I don't have 230V input. So is there any issue with using the available 115V to get the desired output?
Old 28th April 2010, 04:37 PM   #2
AndrewT is online now AndrewT  Scotland
running a transformer at half voltage will reduce the VA by half as well, i.e. the current output rating remains the same.
regards Andrew T.
Old 28th April 2010, 04:46 PM   #3
InlineTwin's Avatar
Thanks.
Old 2nd May 2010, 08:01 PM   #4
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
only secondary voltage is halved, you should be able to get the same power output,
Old 2nd May 2010, 08:57 PM   #5
No the power output is halved. One of the major limitations on the power handeling
is the heat caused by the I R power loss and this loss will be the same at 115v or
230v.
Old 2nd May 2010, 09:02 PM   #6
Tony's Avatar
power delivery is a function of the physical dimensions of the core, and as far as i can see, it did not change....only the input voltage has changed....
yes, copper losses will set you back....but not half va's worth...
Old 3rd May 2010, 03:35 AM   #7
than tang
Old 3rd May 2010, 09:32 AM   #8
the current is limited by the primary copper resistance, by the core size and by the secondary copper resistance.
These all give heat.
If you reduce the primary voltage by half you reduce the core losses slightly. If you take out the same current then the Isqrd R losses are identical.
If the VA is set by maximum internal temperature then effectively the half voltage transformer is limited to it's original secondary current rating, i.e half power.
regards Andrew T.
Old 3rd May 2010, 07:56 PM   #9
Tony's Avatar
power draw is determined by the load connected to the transformer's secondary, not it's specs per se....
Old 3rd May 2010, 08:04 PM   #10
event horizon's Avatar
So what you are saying is it's fine to overload the primary & secondary windings by drawing twice the current they were designed to supply?
I don't think so Rewind the transformer with thicker primary & secondary windings & yes you'll get double the current with half the primary voltage, but then you'd have a 120V transformer anyway
"Never let your morals prevent you from doing what is right!" Salvor Hardin
8 x 230V Toroid Transformers ZenCow Swap Meet 0 21st September 2008 04:17 PM
2 trafos 230V/2x18V 800VA DarkOne Swap Meet 2 15th January 2008 12:50 PM
WTB/Trade: 2x45-50VAC out (115VAC in) 80-200VA harvardian Swap Meet 2 17th November 2006 08:02 PM
Trade a 40V 400VA Toroid for 20V 300VA Toroid john65b Swap Meet 7 10th October 2006 03:49 AM
Looking for 230V >1KVA variac and 230V-230V mains isolation transformer offers Eva Swap Meet 1 28th July 2005 03:00 PM
Page generated in 0.10314 seconds (76.67% PHP - 23.33% MySQL) with 11 queries
