Go Back   Home > Forums > Amplifiers > Power Supplies
Old 19th April 2010, 03:05 AM   #1
jrenkin is online now jrenkin  United States
Default adding and using secondary windings
I have a 400VA toroid power transformer with 400VCT, 5V 4A and 6.3V 4A secondaries.
I am planning to use it in an EL34 PP amp, so for the heaters I need 1.5A per EL 34 and 0.3A per driver (12AT7).
Therefore I will add another secondary at 6.3V.
The question is how best to use the secondaries, as this will determine the wire I need for it.
I could use a heavy wire, 12G and use the new winding for all 4 power tubes, both channels and the other 6.3v winding for the drivers, both channels.
Or, I could use lighter wire, maybe 14G or 16G and use one 6.3V for each channel, two EL34, and their driver.
I am planning on regulating the heater voltage for the drivers, so maybe that makes a difference, since if I divide by channel, I will need two regulating circuits.
Any reason to think that it will impact sound quality or noise depending on how I do this?
Adding Another Secondary to a Toroid SRMcGee Parts 5 17th April 2010 05:22 PM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
cap btween primary and secondary windings? sam9 Power Supplies 8 19th May 2005 06:34 PM
Parallel secondary windings jlm Pass Labs 6 27th March 2004 10:39 AM
opt windings, need some help jazz Tubes / Valves 13 7th November 2003 02:50 PM
Page generated in 0.06201 seconds (67.44% PHP - 32.56% MySQL) with 10 queries
