Go Back   Home > Forums > Amplifiers > Power Supplies
Old 15th April 2010, 11:37 PM   #1
ChrisA is offline ChrisA  United States
Default To series connect dual secondary or not?
I see two different ways to built a split ( +25V, 0, -25V) power supply
1) The transformer has dual secondary and two full wave bridges are used each followed by some filter caps. The two halves are tied to ground after the rectifiers
2) A center tapped transformer is used and the tap is run all the way out the the DC power output
Of course if I have a dual secondary transformer I can connect the two primaries and in effect make a center tapped transformer. So I have a choise. I don't see which is best. In the past I've used CT transformers but now I have a toroid with dual secondary so I want good engineering reason to go one way or the other.
Old 16th April 2010, 06:43 AM   #2
RJM1 is offline RJM1  United States
I don't think that you will see any difference in power supply performance either way. If you go with the center tap you will only need one bridge rectifier at twice the current rating of the non-center tap way with two bridge rectifiers.
help: how to connect 2 pairs of secondary to +/gnd/- jtktam Power Supplies 3 27th January 2010 08:18 PM
dual secondary transformers jesserparker Chip Amps 14 13th January 2007 12:25 PM
dual secondary transformer connected in series Leolabs Solid State 2 6th October 2006 11:38 PM
dual primary//dual secondary toroid larryg Chip Amps 22 6th September 2006 09:24 PM
Dual center tap secondary scottw Power Supplies 0 18th September 2005 07:54 PM
Page generated in 0.07780 seconds (68.70% PHP - 31.30% MySQL) with 10 queries
