LM4562 decoupling...
Old 12th April 2010, 08:45 AM   #11
Nazar_lv is offline Nazar_lv  Europe
Nazar_lv's Avatar
Send a message via ICQ to Nazar_lv
For 4562 local decoupling should be 1 cap between +and- and 1cap from - to ground.
"In developing audio devices we can always find creative non standart solutions that will ensure the best sound" (с) S-Audio.Systems
Old 12th April 2010, 09:06 AM   #12
mikesnowdon is offline mikesnowdon  United Kingdom
mikesnowdon's Avatar
Based on what Naz?
www.drugfreeworld.org
Old 12th April 2010, 09:07 AM   #13
Originally Posted by SoNic_real_one View Post
Low ESR caps on power lines can make more damage than good... The rails inductance coupled with the capacitor needs some damping - usually the "normal" ESR is enough for that. If you go with too lower ESR you will get ringing and other artifacts on the rails.
As for the ideea that caps between rails and ground will "dump" noise there - that is nonsense perpetuated by urban legends.
By the way an OpApm is build, the currents will flow thru the ground back to the PS - on each alternance to the other rail. And that's the current you need to bypass!
Not between the rails, that will ADD more current to bypass at the PS on the opposite rail! Bigger loops instead of short ones.
Best post so far.....
Old 12th April 2010, 12:47 PM   #14
marce is offline marce  United Kingdom
Have a look around the web at decoupling, bypass capacitors and EMC, I think you'll find Naz is correct. Based on thousands of designs and work done on this subject.
The Urban legend is a big base for a lot of EMC engineering in electronics!
Old 13th April 2010, 12:55 AM   #15
Seems pretty non standard form what I have seen. Do you have a link to show me please?
Old 13th April 2010, 01:24 AM   #16
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Urban legendary nonsense. Ringing only occurs when there's something to set it off- do bells ring in the absence of being struck? But its true that low ESR caps can do more harm than good... see below.
You're quite welcome to your own opinion. However I've simmed this in LTSpice so the effect is a real one. Ignore it at your peril
As I've set out on another thread where this came up, there are cases where the current from the opamp does not return to ground. When feeding another opamp for example, or when the opamp is feeding into a chipamp.
Do please explain this further as I'm not clear where you're coming from.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 13th April 2010, 01:33 AM   #17
Another interesting post. Thanks
As I understand it decoupling is basically the process of isolating one stage of an amplifier or circuit from another. This is traditionally done by a locally placed cap from rail to ground. Its supposed to stop noise entering the next stage right?
How does a cap from +VE to -VE have the same effect in bi-polar situations?
Also, if your LTspice sims prove that the traditional method dumps noise on the GND (which its supposed to do no?), then where does the noise go if the cap is between +/- rails?
Old 13th April 2010, 01:41 AM   #18
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
cap between +and- and cap from - to ground came from:
http://www.analog.com/static/importe...ets/AD8099.pdf
also you might have a look:
http://focus.ti.com/lit/an/sloa069/sloa069.pdf
Old 13th April 2010, 01:43 AM   #19
More importantly....
Has anyone compared the 2 techniques on the same opamp in the same circuit, and could comment on the change in sound for better or worse? If you have I'd very much like know how it affected the sound quality.
Thanks in advance
Old 13th April 2010, 01:44 AM   #20
Nice one Dimitri
EDIT: That second link is superb! I will read it properly tomorrow. Bit tired now so off to bed. G'night all!
LM4562 decoupling...Hide this!Advertise here!
LME49720 Vs LM4562.... Ryssen Chip Amps 33 11th June 2017 04:00 PM
AD8066 vs. LM4562 douglesc Parts 21 22nd December 2011 03:41 PM
Line out using LM4562 bluetech Chip Amps 18 30th January 2009 01:44 PM
Self on LM4562 sam9 Solid State 7 17th April 2007 03:11 AM
Lm4562 Ryssen Swap Meet 0 12th October 2006 10:42 PM
