hi! how do I calculate the resistor gate?
i cant find it nowhere. sorry for the bad english.
#2 |
ask the question in your own language and hopefully someone will be able to translate it for us.
Explain why you need the information.
regards Andrew T. |
#3 | |
Minha duvida é: como eu faço para calcular o resistor de gate do transistor mosfet, o que eu devo considerar, e se devo considerar a aplicação Ex: amplificação ou como chave. |
#4 |
Banned
This is what I get from babelfish:
---------------------------------------------------------- Mine it doubts é: as I faço to calculate the electrical resistance of gate of the transistor mosfet, what I must consider, and if I must consider Former aplicação: amplificação or as key. ---------------------------------------------------------- The electrical resistance of a MOSFET gate is very high. >>1M. It is an insulator. Zero current flows into the gate. The gate has capacitance, however, to both drain and source. Current flows into and out of the capacitances. This affects how fast it can respond to switching changes in input voltage, and also its maximum frequency as an amplifier. Sometimes we modify this with a series or parallel resistor. Is your circuit a switch or an amplifier? Post a picture of your circuit. w |
#5 |
I think our new friend is asking for the value of the gate-stopper resistor on a MOSFET.
If this is the case, the general answer is typically in the range of 100 - 470 Ohms. |
#6 |
..............Post have been edited by tinitus
English only please
#7 |
Three methods.
1. Guess. Where speed is not critical, around 100 ohms will ensure the MOSFET will not oscillate. 2. If your gate driver is current-limited, you can set the resistor so it drops 50-100% of the supply voltage in the first instant. This is essentially the largest practical resistor value for such a gate driver. Example: a driver using 2N3904, supplied from 12V, will supply about 200mA. Therefore, the resistance should be 12V/0.2A = 60 ohms. 47 ohms will be fine. 3. In speed-critical applications, you can solve the driver-resistor-gate capactance system and design for a certain rise/fall time. Say you need to drive a 10nF gate in 100ns, from a 30ns gate driver. The RC time constant needs to be about 40ns, or a resistor of R = t/C = 4 ohms. (The driver must be able to supply peak currents around 2A to do this.) Mind that gate capacitance does not include miller effect: to include this, find maximum total gate charge Qg and divide it by the gate voltage to find the effective capacitance. A 10nF gate may have more like 250nC total gate charge at 10V, which is closer to 25nF for the full edge! Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#8 | |
Unfortunately you have just completely deleted his last post, which does not help or encourage! Obviously the forum language is English, but completely deleting the post is surely not the best way to progress. It seems as if it is punishing him for not speaking English, and certainly provides 0% encouragement. Help is usually better than force! Regards, J. |
#9 | |
3. In speed-critical applications, you can solve the driver-resistor-gate capactance system and design for a certain rise/fall time. Say you need to drive a 10nF gate in 100ns, from a 30ns gate driver. The RC time constant needs to be about 40ns, or a resistor of R = t/C = 4 ohms. (The driver must be able to supply peak currents around 2A to do this.) Mind that gate capacitance does not include miller effect: to include this, find maximum total gate charge Qg and divide it by the gate voltage to find the effective capacitance. A 10nF gate may have more like 250nC total gate charge at 10V, which is closer to 25nF for the full edge! |
#10 | |
i need to know how to calculate the resistor used in gate of omsfet, what i need to considerate(VGS, gate capacitance...) i dont know where i read, the gate is an capacitor that charge and descharge, and the resistor controls this time(and the current o dreno). i am working now in a smps of Elliot, modified to get 2500W, using the same fc, but with irf3205. but i need the information, for aplication as a switch (EX: SMPS), and for use it as ampplifier (amplifier class AB). I dont remember what i write in the other post, but was +- this. |
| Which resistor type for emitter resistor? | sajti | Parts | 25 | 8th April 2009 06:12 AM |
| Gate capacitance and gate charge | rtarbell | Parts | 1 | 22nd January 2007 05:11 PM |
| IRFB31N20D gate resistor sizing? | jwagnerhki | Class D | 5 | 17th August 2006 03:50 PM |
| screen-plate resistor and grid leak resistor | metebalci | Tubes / Valves | 4 | 26th February 2004 03:18 AM |
| best way to generate Gate-Drain or Gate-Source short in electret capsule JFET? | capslock | Parts | 2 | 27th September 2002 08:07 AM |
| Page generated in 0.13082 seconds (80.96% PHP - 19.04% MySQL) with 10 queries |
